Thanks Thanks:  3
Results 1 to 11 of 11
Thread: Turn signal cancel and horn wiring with the FFR Steering Wheel
    Member Kiwi Dave's Avatar
    Oct 2017
    Darnestown, MD
    For those of you who have the FFR steering wheel, how have you handled turn signal canceling (required here in Maryland) and the horn wiring?
    Stay healthy
    Aug 2019
    Russ Thompson turn signal hub... Arm for turn signals and has self cancelling and button on the end for horn.
    That's the easiest set-up and I put a foot switch on the floor for hi-lo beam.
    Can't really do much with the FFR steering wheel for that.
    Senior Member AZPete's Avatar
    Turn signal
    If you want turn signals that cancel, and you don’t want to keep the big donor steering wheel, you can modify the mechanism to work with any steering wheel. I installed the Factory Five leather wheel by buying a momo adapter and connecting the donor plastic cylinder, as this photo. Note that the tab triggers a little turn signal lever inside when turned 90 degrees, then cancels it when turned back.
    Horn
    You can discard the cumbersome horn ribbon if you concoct a springy thingy (paper clip or safety pin) that rubs on the copper surface of the momo adapter. I think Factory Five sells an adaptor now, or order a momo adapter elsewhere.
  4. Thanks Kiwi Dave thanked for this post
    Quote Originally Posted by Rockon View Post
    True for a roadster, but OP is asking about an 818 application.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Feb 2019
    Houston, TX
    I have no idea where PO bought his adapter, but my car has the FFR steering wheel and the hub adapter works with the factory clockspring for horn and turn signal cancel. I can dig up some pictures if needed.
    Senior Member fletch's Avatar
    Dec 2018
    Just outside ABQ, NM
    Yes please.
    Feb 2019
    Houston, TX
    Here is a picture of the black plastic card that bolts to the hub adapter and catches the clock spring to cancel the turn signals:
    Attachment 123491
    This is kind of how it bolts to the hub adapter, this is not the FFR one, this is one I 3D printed so that I could mount my cruise control lever.
    Attachment 123494
    And this is how it looks installed. The two holes in the black plastic card grab the clockspring pegs so that the clock spring turns with the wheel.
    Attachment 123486
  9. Thanks Kiwi Dave, DSR-3 thanked for this post
  10. #8
    Oct 2017
    Darnestown, MD
    Attachment 123491
    This is kind of how it bolts to the hub adapter, this is not the FFR one, this is one I 3D printed so that I could mount my cruise control lever. If you have lost the bracket, I can 3D print you one of these, it would work without the cruise lever
    Attachment 123494
    Attachment 123486
    I think this will work for me. Much appreciated Alan!
  11. #9
    Thanks for posting this info! I harvested my donor parts 2 years ago. I have the clock spring mechanism, but not the black plastic card. Was that from your donor, or did it come with the steering wheel kit?
  12. #10
    Feb 2019
    Houston, TX
    Quote Originally Posted by melnjoel View Post
    I believe it came with the hub adapter (previous owner bought all that stuff). I uploaded the files from my 3D printed one to thingiverse so you can 3D print one. If you don't know anyone with a printer I could mail you one.
    https://www.thingiverse.com/thing:4195342
  13. Likes AZPete liked this post
  14. #11
    Got it printed! Thank you for the help!!
