Dear all, I need help! Fully motivated I ordered a bump steer kit from FFR to adress bump steer but it seems that the adjustment is not enough. There is quite a lot of toe in on compression and toe out in rebound. The curve is really not a curve but linear from toe in to toe out.
Even with 6 shims between the tie rod end it is still much to high. I did a bump steer measurement before installing it and there is no difference. I don't think the the setting length is higher than with the original part. Please see picture.
Here is a short video of the measurement through the suspension travel, quick&dirty, see the laser point on the garage wall: https://youtu.be/gL0RyjKDj3o
Am I missing something here? Is there another way to reduce toe in on compression? Raising the inner tie rod is probably not the easiest solution.
Thanks for your help!
Eugen
