Results 1 to 5 of 5
Thread: headlight bucket trim ring question
    Senior Member dpariso's Avatar
    Beach Park, IL
    As I was removing the bottom screw that holds on the headlight trim ring... i heard tiny brittle plastic pieces fall to the floor {{ARGH}}! The plastic screw hole (attached to the bucket) broke. Since FFR does not sell the bucket only, anyone have any ideas to repair?
    So. Bay (So. Calif.)
    Not sure what the original piece/mount looks like. I'd probably try JB Weld, drill and tap for a #6 or 8 machine screw. Or if it's a tab that sticks out, a small piece of aluminum angle, bent to the right angle, drill and tap.
    Senior Member Fixit's Avatar
    Minneapolis 'Burbs
    Looks like there might be enough "meat" left there to push a "Tinnerman" clip on. They're available in common machine screw thread, or for a sheet-metal screw.
    John D. - Minneapolis 'Burbs
    Super Moderator
    R. Button's Avatar
    Elmira, NY
    Dpariso, Would you rather have a new headlight bucket? On my shelf of parts I have a new headlight bucket. This is just that a new bucket, no screws, no trim ring, no rubber seal, etc. Still in the plastic bag. If all your other parts are usable this should fix you up. If you have other pieces you need for the headlight let me know as I have collected a few parts over the years! I just need an address to ship it too. Send me a IM with the address and I'll start trying to find a box for it and get it off to you.
    Last edited by R. Button; 05-05-2020 at 02:04 AM. Reason: added pic of the headlight bucket
    Ralph Button
    FFR 1436 (PROUD Owner of an Original Mark I)
    400,013 miles as of 11/1/2009
    417,840 miles as of 8/12/2010
    435,021 miles as of 12/19/2011
    Now a well broken in 347 engine
    523,145 miles as of 7/29/2014
    601,165 miles as of 6/1/2018
    615,215 miles as of 4/23/2022
    "It's not about the destination, it's the about the journey. And where is your journey taking you?"
    "... Not all who wander are lost!... --J.R.R. Tolkien
    The old "classic mini" used a 7" plastic bowl.. Seven Mini: https://www.7ent.com/products/headla...tic-s5400.html
