Thanks Thanks:  10
Likes Likes:  6
Results 1 to 15 of 15
Thread: Tonneau cover, homemade
    Elk Grove, NorCal
    In anticipation of taking the Cobra out on weekend getaways, I made a tonneau cover. A photo of an original AC Bristol that participated in the 1000 mile Mille Miglia in Italy was my inspiration. I'm by no means a seamstress; I just enjoy doing something new and making things. I was hoping I could drive with the cover attached on the passenger side and with the driver side rolled up. However, the passenger side flapped around in the wind a little too much for my liking. It is not bad, I just don't want the flapping cover to ruin my paint job. Anyway, it is a good cover for when I retire for the night at some motel, hotel, air bnb, or wherever the wind takes me. There is no provision for the steering wheel so I have to remove the wheel to completely button up the cockpit. And that's ok too as it is a bit more security.
    I already placed the male lift the dot fasteners on the body during construction and after paint. All of the materials and supplies I used, including the sewing machine, thread, tonneau fabric, edge binding, basting tape, fasteners, I mean everything where purchased from sailrite.com. So I first made a template with that clear material and held it in place with double sided basting tape. I cut the template to size, along with a circular hole for the fuel cap. Then I placed the template on the black tonneau cover material and cut it. Then on the outer edges, on the bottom, I sewed an extra 3.5" band around the perimeter for added thickness and strength. Then I attached the 2 front center lift the dot fasteners and the 2 rear center lift the dot fasteners to center the whole cover on the car. Then I marked where the zipper was to be placed and then sewed the zipper on. I used the "bind and slit" method of stitching the zipper. The method is on Sailrite's YouTube channel. Then I attached the remaining fasteners working from the center out. Then I sewed the edge binding on. And finally I used the 1" binding, folded it over and stitched it together to make 4 straps. The straps where also stitched on with velcro. Here are some photos:
    build thread: http://thefactoryfiveforum.com/showt...-USRRC-vspeeds
    Build School: July 14-16, 2017
    Kit purchased: July 25, 2017
    Kit delivered: September 13, 2017
    First Start: December 22, 2018
    Body painted and kit completed and drivable: July 2019 (but still not done)
    CA SB100 Registration: January 2020
    Mk4 - 289 USRRC Roadster kit, Roush 427SR with Schneider Racing custom camshaft, Fitech EFI, TKO600 (.64-5th gear), 15" wheels, stock brake calipers, under car exhaust with Spintech 7000 muffler, no roll bar, Russ Thompson turn signal, removable steering wheel, and many other small upgrades and modifications
  2. Thanks Sdonnel, WIS89 thanked for this post
    Nov 2018
    Centennial, CO
    Nice work. I love the look of an old classic car.
    Bradley
  4. Thanks Vspeeds thanked for this post
  5. #3
    Southport, NC
    Nice work, I've copied your details here and filed it away for another future project for myself. Yes, I used to drive my old sports cars with the passenger side closed with no problems but I have heard that comment from others about the FFR roadster. Possibly add an internal strap to pull the passenger side down to stiffen the material when closed. I think I've seen that on other British cars.
    I once had a heavy duty sewing machine and taught myself. I used to dumpster dive at a sail makers dumpster in the Annapolis, MD area and got some really nice pieces of 'throw away' material. Sewed up a bunch of items for my sail boat and made a bunch of Christmas gifts too.
    George
  6. Thanks Vspeeds, WIS89 thanked for this post
  7. #4
    Jun 2015
    Maumee, OH
    That looks great. I like the fact that you used the NRG hub and didn't have to account for the wheel sticking up. Most people walking by would never know there's supposed to be a steering wheel sticking up above the dash/cowl. When I order my snapless tonneau, I may have them omit the steering wheel pocket, as I'm installing the same hub as you. I love the ideas that get shared on this forum. As long as money and time allow, I'll incorporate as many as I can into my build.
    Scott
    Built FFR9457. 351 Windsor, TKO600, 3.73. Fitech EFI. Russ Thompson throttle pedal, turn signal, and trunk pan. Carbon Fiber dash with Speedhut Revolution gauges. Paint by Jeff Kleiner.
  8. Thanks Vspeeds thanked for this post
  9. #5
    Elk Grove, NorCal
    Quote Originally Posted by GWL View Post
    George
    George
    Thanks for the idea for the inside strap. I’ll try that out.
    It’s funny; I have a decent paying job but I also dumpster dive. One man’s garbage is another man’s treasure.
  10. #6
    Southport, NC
    Quote Originally Posted by Vspeeds View Post
    George
    I laugh...and being retired I still grab an occasional piece of wood (or two) from the dumpsters at construction sites in our community.
    George
  11. #7
    Lost Wages, Nevada
    Small boat sail "stays" (or anything similar) slid into pockets sewed on the underside will help stop the flapping . . . run them front to back for the best effect.
    Doc
  12. Thanks Vspeeds thanked for this post
    Likes WIS89 liked this post
  13. #8
    Elk Grove, NorCal
    Thanks Doc
    Ill look into those "stays"
  14. #9
    Tybee Island, GA
    Great Job!
    Videos are at: YouTube Videos
  15. Thanks Vspeeds thanked for this post
  16. #10
    Helicopter Wrench-Bender ChopperJustin's Avatar
    St. Georges, DE
    What template are folks using to accurately place the Lift-A-Dot studs on the body? - thank you
    "Gravity, It's The Law"
  17. #11
    Nov 2018
    Centennial, CO
    Quote Originally Posted by ChopperJustin View Post
    I wanted a template too when I put my Whitby tonneau on, as they only showed where the rear posts go for the soft top. For the front I used historical photos, but ended up placing them where they would make the tonneau the most even and taught.
    Bradley
    Bradley
  18. Thanks ChopperJustin thanked for this post
  19. #12
    Elk Grove, NorCal
    I didn’t use a template neither. I did however replicate a 289 slabside from Superformance. I took measurements of their lift the dot locations. I could post/send them if you want.
  20. #13
    Senior Member MPTech's Avatar
    St. Louis, MO
    If you've got a heater, a tonneau is even better! Keeps the warmth in there REAL NICE!
  21. #14
    Elk Grove, NorCal
    Quote Originally Posted by MPTech View Post
    No heater on this build. But my electric seat heater seems to suffice for California weather. High 50’s F in the winter. I made the cover mainly for covering up the cockpit overnight when traveling.
  22. #15
    Senior Member tbl100's Avatar
    Mar 2019
    Roseville, CA
    Nice job. Looks great. I think I'll get the removable steering wheel hub as well.
    Mk4 Complete Kit delivered 5/2019, Gen 2 Coyote, TKO 600, IRS, Wilwood F/R, Power steering, Halibrand 17” X 9” Front 17” X 10.5” Rear, Nitto NT555 G2 F/R
  23. Thanks Vspeeds thanked for this post
