Results 1 to 11 of 11
Thread: Inner splash panels and mirrors?
    Jan 2020
    Hi All!
    So I'm trying to mount the inner front splash panels and the instructions that I have are pretty different than the panels I have...
    In the manual (picture uploaded) it shows a pretty long part and the part that I have seems to be the beginning of it (without the part that goes all the way to the front), is there another part that I'm supposed to attach to it to extend it?
    Manual pictures:
    vs
    Also for the one that mounts closer to the door the instructions show no objects blocking the piece from fitting but the piece I have has a slit cut in it and the hood pin blocking the piece from mounting "flush"
    For the mirrors...
    I noticed that the previous way that it was mounted left the passenger-side mirror completely obstructed from the A pillar so I've been trying to figure out the best way to mount them now... It seems like the spot where mirrors are typically mounted (the little triangle thing) won't work because it's not part of the door and therefore gets hit by the windows whenever the door opens... anyone have creative solutions around this? Maybe making something that attaches to the door where the triangle part is supposed to typically be?
    Any suggestions are extremely appreciated!
    STiPWRD posted some excellent pictures for me in my build thread related to those aluminum pieces. Post 111"
    https://thefactoryfiveforum.com/show...l=1#post381880
    As for the mirrors, the kit comes with two mounts that attach the OEM mirrors to the doors. You don't use those triangle pieces.
    Jan 2020
    Quote Originally Posted by sgarrett View Post
    Woah, thank you! Those pictures rock! (and thanks @STiPWRD !) I figured out I had an outdated version of the manual... the new version has a full diagram of the aluminum pieces! (page 584 if anyone is interested) .
    I'm still having problems with the #80150 piece where the slot at the top doesn't line up... been trying all day, did you guys trim the piece to make it fit?
    Also with the piece that goes all the way to the nose (#81086) I have a *HUGE* gap, is this normal...? Am I aligning it wrong? Here's a picture:
    and
    any help is appreciated!
    Jul 2017
    The Villages Fl.
    I trimmed mine to fit. It has to follow the contour of the fender after it is installed.
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    The nose piece on mine was a long way from creating any seal too. Being nuts about stuff like that I riveted in extra pieces from my scrap pile to tighten things up. Probably overkill but also made bottom and top strips along the radiator, and bulb seal on all of it to hit the hood and fenders. The H6 motors are heat monsters and I wanted the radiator to have every chance to only get cool air in the front without recirculating hot air from back to front easily.
    Jan 2020
    Interesting, well I guess I'll have to trim it!
    For the front aluminum that goes towards the nose, what are you supposed to do with the top parts? They seem like they're supposed to bend forwards but I fail to see how that would help with anything other than riveting it in on the top and then trimming away the excess?
    Leesburg, VA
    I had to do a lot of trimming on my splash guard aluminum as well, almost every piece needed some trimming. You just size it up, like in post #3 and trim when it interferes with something. Like Art, I also added some metal when a gap was too big.
    For #80150, I extended those slots a little bit towards the inside to help them slip over the hood pin brackets. Then you should be able to get that piece up against the frame. The hood pin bracket will stick through the slot.
    I had a chance to take a couple of pictures of the mirror mount for you. Here it is with the door open and closed.
    You need to remove that triangle piece from the mirror and then you mount it to that bracket that comes with the kit.
    Bolton, Ontario, Canada
    An old thread, but I'm going through my aluminum pieces now with reference to the instructions. Do you put all the front inner panels in place after the front fenders are on? Seems like some of the instruction pictures show the body on, and some not. It would be easier to do it before the front fenders are on, but if they need to be trimmed to match the body then that wouldn't be a good way to do it.
    Rick
    Apr 2020
    Rick, I haven't done all my splash panels yet, but from what I have done, I'd suggest drilling as early as possible to avoid obstructions, and riveting and trimming as late as possible to accommodate any obstructions you added along the way.
    RPG
  11. Thanks FFRWRX thanked for this post
  12. #11
    That sounds like a good way to do it. Thank you.
