![Forte's](https://www.factoryfive.com/wp-content/uploads/2015/04/fortes.gif)
Non turbo donor with turbo engine
New to Subaru’s and looking to build a 818. I have access to a 02 non turbo Impreza with a bad motor for $700. Is it possible to use it as a donor and go with a JDM turbo engine? Would I just need a JDM ECU and a new wire harness? Would it be better to look for a different donor, I definitely want to go turbo.
I would keep looking for a turbo donor car if I were you. Normally aspirated cars will have a different ecu & wiring harness as well as some different engine internals. Some ppl have built their car using the jdm route, then buying their miscellaneous parts from a salvage yard.
I’m just a little hesitant because all of the wrx cars around me have a ton of miles and they still want 10k for. I feel a little more comfortable with a lower mileage engine which is why I was looking to go with a JDM. I was just unsure what else I would need for it to work.
I went with a 04 Forester XT from Coparts. Same engine as o4 STI but with a WRX size turbo and intercooler. You can get them for about 1k.
Here is a sample on Coparts today.
![Breeze](https://thefactoryfiveforum.com/attachment.php?attachmentid=40534&d=1428868052)
