Results 1 to 12 of 12
Thread: ST2 ABS install in FFR#48
    Senior Member johngeorge's Avatar
    Nashua, NH
    Started on the ABS install over the weekend! welded mount to frame, ripped out all of the brake lines, ran rear lines forward to ABS, rewired ABS connector moving Pin10 to Pin6, removing pins 20, 24, 34, 39 (I couldnt figure out at first how to take them out, if there was a tab you had to press down, so I ended up yanking on the wires real hard from the back and they came out.)
    Parts used for FR500S ABS (pics of install)
    2007-2009 Ford Mustang GT500 ABS module (HCU – ebay has item, connector on back not on side, do not buy newer year model) $200
    ABS Connector $51.24 Motorcraft WPT1356 Wire Assembly (relocated wire 10 to 6 and removed wires 20, 24, 34 & 39 that are not required
    Tube nut fitting – 4 of 10M x 1.0 bubble flare to 3/16 line BLF-39C-5
    Tube nut fittings – 2 of 12M x 1.0 bubble flare to 3/16 line BLF-48C-5
    wheel front sensors (2 of them, $34.79 each) BRAB291
    Wheel rear sensors (2015 IRS, 2 of them,$11.85) BRAB406
    Pics
    http://johngeorgeracing.com
    Nashua, NH
    Nashua, NH
    Apex, NC
    I am following this with great interest.
    2012 NASA-SE FFR Champion
    2011 NASA-SE FFR Champion
    Race page - http://www.mh-motorsports.com/race.shtml
    Team Facebook page - http://www.facebook.com/pages/MH-Mot...s/264814350042
    Nashua, NH
    Plumbed all of the brake lines and masters to/from ABS module this weekend, even bled the brakes! Found I had to remove caliper from rotor, and lower it as much as flex line would allow to get air out of system. Also started on the wire harness for abs sensors.
    Nashua, NH
    where everything goes
    wiring diagrams
    Folsom, CA
    I love this writeup!
    I think from the content I can find, the latest prices are a bit different - I put them in a spreadsheet...
    https://docs.google.com/spreadsheets...it?usp=sharing
    looks like ~$630 to set up ABS if the HCU can be found - there are several online... the M-2353-A is nearly impossible to find anymore though.. but designed for slicks at the track, maybe not what everyone needs anyways...
    who all has done this setup? i think ABS is a great option!
    original post https://community.drivenasa.com/topi...comment=370690
    Todd
    Senior Member Hacksaw84's Avatar
    Jun 2017
    I have ABS on my build following this writeup by John George. My car isn't driving yet so I am not sure how it all worked out.
    The one thing I am not sure about is the rear sensors. I believe the 2015 sensors are electronically different than the ones he used on his rear brakes.
    Michael aka @my_cobra_build on Instagram
    Base MK IV Roadster with several options. Body is Lamborghini Grigio Lynx w/ Audi Vesuvius Gray stripes. 25th Anniversary FFR wheels. Seats and interior by Intatrim.
    Gen1 Coyote w/ Comp Cams & Cobrajet manifold. Tremec TKO 600 w/ a midshift kit. 2015 IRS w/ 3.73 Torsen diff. FFR Headers, Gas N Pipes, Power steering & power brakes.
    Folsom, CA
    Quote Originally Posted by Hacksaw84 View Post
    I think the rears are correct, haven't fit them yet but they look like his photos
    the fronts however look different
    and my setup with BRAB291 part as listed above
    Todd
    Folsom, CA
    update - had to drill a few extra holes to align the different sensors than Russ' brackets are made fore - I missed this in @Johngeorge's pics... here's a pic of the aligned ABS sensors built for the '05-09 FR500 setups
    Todd
    Folsom, CA
    bump - there are some who have done this as well; I'm almost done with my setup!
    https://cobradreams.com/2021/04/12/g...s-hcu-mounted/
    Todd
    Dec 2020
    Denver
    Hey Toadster and other ABSing folks, what's the latest thinking on "best" ABS module for our roadsters? Having a hard time finding the 2C353-AB control module. Are there other part numbers for it, or other modules folks have tried that might work?
    On Mustang forums I've seen chatter like this:
    How does the FR500S & C differ from the S197 unit?
    The FR500C and FR500S units were both specifically calibrated to those cars, on race tracks, with the correct suspension and tires. It is a pure race tuning that doesn't have any of the compromises found in street car ABS.
    Which makes me wonder if this is all just going to be "better than nothing" but finding an ideal is a pipe dream? Anyhow, it's making me a little braver to try something farther outside the box, provided I could still disable the ABS when needed.
    Also, in my hunting found this nice thread, our friend johngeorge posted a little more info here:
    https://community.drivenasa.com/topi...tallationquot/
    Juan
    Roadster kit received June 9th, 2021. First wrench turned July 7, 2021. Gen 2 Coyote in the mail August '21.
    Quantum Mechanic's Garage Build Thread
