Results 1 to 4 of 4
Thread: Electric steering assist blue wire
    Member Mrallsport32's Avatar
    Cotati California
    Ok I have Gen 2 33. I’m finishing up my wiring. My electric steering assist that came from Factory Five has the control module with four plugs. I have four wires that I need to connect, red to full-time power, black to ground, white to keyed power, ok that was simple.... and then there’s a blue wire that is not mentioned anywhere. Can someone, who has the same electric steering module, help out. Where does the blue wire go and what does it do?...
    Gen 2 chassis #1121 delivered 2-10-19. SBC 400 with FI Tech dual quad, 700R4 trans and IRS.
    May 2018
    Pinckney, MI
    Just get rid of it. It is not used. The white wire is the on/off switch. I checked with FFR and they told me the same thing.
    - Peterh226
    35 Hot Rod Truck (Ext) Delivered 11/21/24
    33 Hot Rod Gen 2 #1134 ~1400 miles
    54 Pontiac Star Chief
    05 F-150
    Cotati California
    Quote Originally Posted by peterh226 View Post
    Thank you. Does anyone know what it’s for. ?
    Kingsland, TX
    The blue wire is used for diagnostics of the control module. I'd cap it off and tape it up with the harness.
  5. Thanks Mrallsport32 thanked for this post
