Electric steering assist blue wire
Ok I have Gen 2 33. I’m finishing up my wiring. My electric steering assist that came from Factory Five has the control module with four plugs. I have four wires that I need to connect, red to full-time power, black to ground, white to keyed power, ok that was simple.... and then there’s a blue wire that is not mentioned anywhere. Can someone, who has the same electric steering module, help out. Where does the blue wire go and what does it do?...
Gen 2 chassis #1121 delivered 2-10-19. SBC 400 with FI Tech dual quad, 700R4 trans and IRS.
Just get rid of it. It is not used. The white wire is the on/off switch. I checked with FFR and they told me the same thing.
- Peterh226
35 Hot Rod Truck (Ext) Delivered 11/21/24
33 Hot Rod Gen 2 #1134 ~1400 miles
54 Pontiac Star Chief
05 F-150
peterh226
Thank you. Does anyone know what it’s for. ?
Consummate Learner
The blue wire is used for diagnostics of the control module. I'd cap it off and tape it up with the harness.
