Likes Likes:  2
Results 1 to 17 of 17
Thread: 8.8" Differential Cover
    Aug 2019
    Alvin, Texas
    I was reading that Hoonatruck had some issues with using an aftermarket diff cover. Looks like it was in the way of his panhard bar.
    Has anybody else experienced any clearance issues?
    Senior Member Pat Landymore's Avatar
    Dec 2018
    SW Calgary, AB
    Yup, I did.
    I just made my own home brew version of a Mustang pan hard relocation kit. My truck is currently masked for box painting later today in my garage, so it will be tomorrow before a photo of my solution is available...
    Go to a website such as CJ Mustang parts (apologies to
    the admin if they are not a sponsor...) and look up 2005 - 2014 Mustang panhard bar.
  3. Likes RuffShod liked this post
    Dec 2018
    SW Calgary, AB
    Link
    https://www.cjponyparts.com/bmr-panh...014/p/PHBRB-V/
    Again my apologies to admin if this is not kosher...
    Aug 2019
    Alvin, Texas
    Thanks Pat! I looked it up. That is a simple fix!
    Thanks again!
    Dec 2019
    Thank you, I saw where some guy welded up a bracket, but since I don’t have access to a welder, this will be a big saver.
    Dec 2018
    SW Calgary, AB
    Note:
    The Mustang guys say it doesn’t seem to affect their handling but please remember this truck is different.
    Please be careful until your certain how it affects your truck.
    All I’ve done is put down a bunch of “11’s” in my back alley and that felt fine, launched dead @$$ straight.
    Dec 2018
    SW Calgary, AB
    F.W.I.W.
    Here is my quickie panhard relocation kit. Basically an extra long grade 8 bolt with washers to take up the space in the original location, and very important, a washer over the outside of the rod end so that if it does pop out of place, the washer will keep the panhard rod from falling completely off the truck and ending my life prematurely.
    View from drivers side
    View from passenger side
    Mar 2013
    Fort Collins, Colorado
    Just for general information, here is a great video on the subject of aftermarket diff covers:
    https://www.youtube.com/watch?v=9-yG3D3JBRs
    MK2 #3319.... On the road since 2002 with a lot of upgrades
  10. Thanks Pat Landymore thanked for this post
  11. #9
    Aug 2019
    Alvin, Texas
    That was pretty interesting.
    I think I am gonna use a G2 cover. It is similar in shape and size of the stock stamped steel.
  12. #10
    Dec 2019
    Based your experience I think I will try your way before buying the part.
  13. #11
    Aug 2019
    Alvin, Texas
    Does anybody know if the girdle system is even necessary? I only see them used mostly on the 8.8". Is there an issue?
  14. #12
    Aug 2019
    Alvin, Texas
    G2 is out. After reading reviews...it seems they have a QC issue.
  15. #13
    Dec 2018
    SW Calgary, AB
    Ford Racing has a nice cover, not much more $ but OEM engineering
    To the O.p.’s question, the only time a reinforced cover is actually needed is when you are doing hard launches with higher HP...and with traction. The reinforcement bolts actually support the ‘main caps’ of the diff as the torque of a hard launch is trying to blow them straight out the back cover.
  16. Likes RuffShod liked this post
  17. #14
    Aug 2019
    Alvin, Texas
    Went with Summit.
    https://www.summitracing.com/parts/sme-8510500nl
    Has girdle, magnetic drain plug, comes with ARP SS hardware, affordable and looks good!
    And no logo!!!
  18. #15
    Dec 2018
    SW Calgary, AB
    That’s a really nice cover, especially at that price!
    The Summit branded stuff is awesome.
  19. #16
    Dec 2023
    8.8 DIF girdle cover, I'm looking for one that says COBRA, Somewhere I seen a picture of one, it was aluminum and the word Cobra was casted into the girdle, if anyone knows anything about this girdle please reply thanks Mike
  20. #17
    Prescott, AZ
    Quote Originally Posted by RuffShod View Post
    Yes, I had interference issues but not with the panhard bar. I bought one of the Ford Performance all aluminum diff covers, a beautiful cover. I had the FF Metal battery box mounted in the upper trunk area. I had some contact between them. I was able to grind down one corner on the battery box to eliminate the interference. It did not take much, maybe 1/8 inch ground off the corner. Fortunately the visible damage was on the battery box and not the diff cover.
