Thanks Thanks:  3
Likes Likes:  7
Results 1 to 19 of 19
Thread: 295/45/18 too big for the front?
    Dreamer j33ptj's Avatar
    Wassenaar, The Netherlands
    Would those tyres/wheel size be too big for the front (with 28/12/18 MT Sportsman tyres)?
    Just curious...
    RJ
    Too big in what way? Are you using fenders? Do you have power steering? Looks?
    I have no power and 275 fronts and find them just fine. I see many '35 trucks (and some 33's) have much wider, like 335!
    I would use power steering and bike fenders...
    Jun 2018
    North Vancouver, BC, Canada
    The FFR front bike fenders will not fit 295s without major mods (i.e. splitting down the middle and widening significantly)
    Here's the FFR fenders with 245s (18) on the front. 255s can probably squeak in with more trimming.
    Gen 1 '33 Hot Rod #1104
  5. Thanks j33ptj thanked for this post
    Simi Valley, CA
    Here is a tire / wheel size calculator that I found useful: http://www.rimsntires.com/specspro.jsp
    FWIW, I have 245/45-18 fronts and they fill up the full fenders pretty well.
    Keith HR #894
  7. Thanks j33ptj thanked for this post
  8. #6
    Seasoned Citizen NAZ's Avatar
    255/35ZR18 under bike fenders and no power steering is no problem.
  9. Likes shmelty, RuffShod liked this post
  10. #7
    If you wanted pic of 275 fronts (GT500 wheels/tires) here's an old photo that shows mine well:
  11. Likes shmelty liked this post
  12. #8
    Thanks all for the input, maybe need to put skinny tyres in the front!!
    Rear: 28x12R18 front 27x8R17... would look more like a drag-racer than....
    I wish there was some software that could assist in visualising these things!!
    Robert
  13. #9
    Simi Valley, CA
    I'm running 305/35-20 in the rear.
    The calculator I linked above has a graphic that rescales when you when you enter new data, and it shows 2 different tires/wheels in one screen so you can get an idea of the relative sizes. Also, I found these wheel visualizers helpful: http://www.billetspecialties.com/sto...el-visualizer/ or one at http://www.newstalgiawheel.com with more brands.
    HTH, Keith HR #894
  14. #10
    I used the http://www.rimsntires.com/specspro.jsp already a few times for other car wheels. I actually meant a design package of sorts where you can play with the hotrod 33 for different designs/wheels/paint etc!!
  15. #11
    There is.. http://www.hokdigitalpaintbooth.com/
    Here's some I did. It asks for wheels/tire size as one of many parameters.
    I don't want to oversell it though - it's not perfect. It's pretty tricky to setup/use, couldn't stripe over the body as you'd expect, and just runs on windows. Using vmware fusion on my mac won't work, you have to use Bootcamp, which is a pain. I remember tire sizes were odd - you couldn't just say 335/35 for example.
  16. #12
    Village Mills, Texas
    Here is what I went with. 26x8x18 front and 29x18x20 rear.IMG_0290.JPGIMG_0291.JPG
  17. Thanks j33ptj thanked for this post
    Likes RoadRacer, JOP33 liked this post
  18. #13
    I live in Nederland too!! But on the other side of the pond! hahahaha!
    What wheel size are you running at the front, width?
    thnx
    Robert
  19. #14
    So just realised that especailly for the rear you need to know how wide the body is and the IRS axle, anyone knows that?
    this would determine the spacing of the wheel...
    thanks
    Robert
  20. #15
    I’m getting ready to put on nascar tires...... because they’re cooler than not.
    33 Hot Rod #1133. LS/TKO600
    Titled 2-28-20
    MkI.IV 2643k
  21. Likes j33ptj, Michael101 liked this post
  22. #16
    Jun 2018
    Quote Originally Posted by j33ptj View Post
    thanks
    Robert
    The manual has a section on max size tires including backspace, it is accurate and applicable for all 3 FFR supplied rear ends including IRS. I have 315/30R18 with 6" backspace with fenders and just clears body so 6.25 would not work for example
  23. #17
    Simi Valley, CA
    thanks
    Robert
    I have 20" x 10" wheels with a 5" backspace on a Gen 1 '33 with the 2015 IRS. I don't have the measurements handy, but I have a minimum 1" clearance between the body and tire sidewall. The FFR wheel size recommendations for the IRS weren't in the manual when I bought mine, so I had to wing it. HTH, Keith
  24. #18
    Jun 2018
    The gen1 manual provided specs for max size wheels/tires with and without fenders. There wasn't any info about which rear ends were applicable at all. Called Tony and he explained that all 3 rears that they sell are the same width so the size recommendations are independent of which rear.
  25. #19
    the 3G manual hasn't been updated from the previous versions, Only shows the rear solid axle:
    Information is separated into groups of wheels/tires used on Hot Rods without fenders and those with
    fenders, and it is also important to note that this information is based on using a standard width
    (59.25”) Ford 8.8” solid axle.
    and information on the wheels with fenders:
    Front maximum wheel width and Backspacing: 9.00” with 5.50” Backspace
    Front maximum tire width: 255mm
    Rear maximum wheel width and Backspacing: 11.00” with 6.00” Backspace
    Rear maximum tire width: 315mm
    Front / Rear maximum tire diameter: 25.7”
    But it would be good to have to body width and axle (IRS) width confirmed... Fenders can be easily modified to fit, is my impression...
