Results 1 to 6 of 6
Thread: Cars and Coffee in Rancho Cordova, Saturday June 27
    Senior Member Mark K's Avatar
    Hi, all. C&C Folsom is still on hiatus, pending approval from the city. However, one of their sponsors is holding one at their store parking lot. The Polishing School, 11311 Trade Center Drive, Rancho Cordova, 7-10am.
    FYI.
    - m
    FFR9280RD MK4 base kit, 2004 Mach 1 donor, PS, PB, ABS, TC, CC, PATS, Summit heater, DIY wire diet, RT pedal/trunk/turn signal, FFR LCAs, FFR 3-link, 17x9 FR500s all around, Ford Magnetic Gray with custom Kandy Orange stripes (Ken's Custom Auto Body)
    Sacramento CA
    Thanks for the info!
    Side question, are you carb or efi?
    EFI. Entire drive train was lift and shift from the Mustang to the Roadster. Only change was slight tuning to the ECM, adding a bit of timing, and removing the secondary O2 sensors.
    Elk Grove, NorCal
    Thanks for posting this. I’m thinking about going. Anyone else?
    Kit purchased: July 25, 2017
  5. Likes Mark K liked this post
    I'll be there.
    Sacramento CA
    I would love to, but dont think I can !
