Results 1 to 5 of 5
Thread: Tfs 11r on 289 with stock heads?
    Senior Member OttawaFFRer's Avatar
    Ottawa, Canada
    my hope and dream of using worked iron heads on my 289 are out the window.
    The tfs 11r has a similar combustion chamber.
    I see there can be issues with piston clearance.
    Your experience is appreciated, can I do it with stock flat tops with valve reliefs at stock position?
    edit to include cam specs:
    int exh
    valve adjustment .018 .020
    gross valve lift .529 .542
    dur @ .0.0 tappet life 271 279
    valve timing @ .050 open close
    int: 12 BTDC 44 ABDC
    exh: 47 BBDC 15 ATDC
    @106.0 intake centerline
    int exh
    duration @ .050 235.00 242.00
    lobe lift .3310 .3390
    lobe separation 106
    Victor
    10 years after my roadster build....
    289 FIA (pickup 28/08/20 if covid permits)
    currently building a 289 and accumulating parts needed to finish a Canadian Kit.
    Tired of Waiting! Briansshop's Avatar
    Jun 2020
    MD
    I've run 11Rs on a stock mid 90s 351w shortblock with no issues. Cam choice will have a lot to do with it.
    Ottawa, Canada
    What should I be considering in a cam? Less lift or a shorter duration?
    Jun 2020
    MD
    The short answer is both. Typical the exhaust valve is the first issue since the piston is chasing it as it's closing. You could call TFS and see what they have to say about it. In the end it might come down to you just having to go for it and see if your combo choice will work. I ran a TFS cam that was thought to not work,but when I installed it,the piston to valve clearance was fine. https://www.summitracing.com/parts/tfs-51403002
    Ottawa, Canada
    These are the specs of the cam I was going to run with stock 289 heads, any chance this will work with the TFS 11R?
    int exh
    int exh
    lobe separation 106
