Says it's for an FFR truck:
WOW! Not sure how he is going to get it to hook up!
FFR Gen 2 35 truck, Barrett Jackson edition # 4, chassis # 81, 525HP LS3 & 4L75E, 8.8" 3 link.
That will be a fun ride when he gets his truck done. I like it!
As for getting all that power to the ground, It'll be easier to set the rear suspension up to hook than it will be to package all that turbo equipment in the small truck and still get most of the weight over the rear axle.
That might be a bit excessive.
For some people, too much is just right. Don't forget Tim The Toolman Taylor: https://www.youtube.com/watch?v=kBNPAJLhKZ4
