Results 1 to 20 of 20
Thread: Remaining Parts from Build
    Nov 2018
    Hi All,
    I have the following unused parts for sale. The parts are all new and never hung. If it is black (and usually isn't), it is powder-coated. All prices are negotiable and do NOT include shipping (22079 zip code), so feel free to make reasonable offers!
    Inline Fuel Filter $10.00 (Sold)
    Non EFI Fuel Pickup $10.00
    Shifter Boot (no chrome ring or shifter) $10.00
    Rear Grommets $10.00
    Coyote PCM mount $5.00
    Pedal Pads $35.00 (Sold)
    Hood Pin Set $10.00
    Accelerator Pedal $30.00
    Accelerator Cable $20.00 (Sold)
    Quick Jacks $125.00
    Side Mirror $20.00 *each
    Vinyl Dash with Glovebox $200.00 (Sold)
    Blank Dash Vinyl (pad attached to back) $25.00
    Mk IV Trunk Carpet $20.00 (Sold)
    Headlight Switch $15.00 (Sold)
    Fan Thermostat $15.00
    Brake Lines and Banjo Bolts $10.00 (Sold)
    Speedometer sender $15.00
    Battery Retainer $10.00
    Clutch Quadrant Assembly $20.00
    Factory Five Emblems Free (Gone)
    Overflow Tank $40.00
    Radiator Tubing $10.00
    Headlights $15.00 *for both
    Heater Components (Control Knob and Cable, Control Valve, defroster vents, defroster covers, vents, and about 5-6' of tubing) $40.00
    Power Steering Hoses (came with kit) $40.00
    Clutch Cable $30.00
    Unknown Mounts?? Free
    Round Tubing Mount $5.00
    Radiator Fan Mounting Brackets $10.00
    Reservoir/Master Cylinder Hoses $5.00
    Conical Air Filter (3.5" Inner Diameter) $20.00
    Silicone Coyote Intake FFR part# 16404 $35.00 *has vacuum ports
    5 pin extensions (2018 Mustang) $40.00
    Streetworks Headlight Reminder $25.00
    Coyote O2 sensor DY-1296-FL3Z-9F472-A $40.00
    Coyote O2 sensor DY-1308-FR3Z-9F472-C $35.00
    Front Brakes (Rotors, Pads, Calipers, bolts, etc.) $250.00
    Uncoated Side Pipes $300.00 (Sold)
    Steering Wheel Center $20.00
    Senior Member Jim Wehr's Avatar
    Hamilton, VA
    I'll take the Factory Five emblems.
    I’ll take the side pipes,pedals,and trunk carpet. My zip is 79119. Pm me thanks Jeff
    Senior Member Joe Campbell's Avatar
    Idaho Falls, ID
    If the dash big holes are 3-3/8 I'll take it. The website doesn't say.
    FFR7859 - graduated 5/16/16; '11 Mustang 5.0 'vert; '93 Mustang Notch; '98 F150; 4760 build website; FFR-3144 rebuild
    Nov 2018
    Joe,
    Unfortunately, the dash's openings are 3 7/8".
    Nov 2018
    Jeff / Jim,
    PMs sent.
    May 2018
    Merritt Island, FL
    PM sent on accelerator (throttle) cable.
    ill take the side pipes,trunk carpet and pedal pads. my zip is 79119 Thanks Jeff
    Senior Member Hacksaw84's Avatar
    Jun 2017
    Curious why you didn't use the O2 sensors? Switch to the longer F150 versions?
    Michael aka @my_cobra_build on Instagram
    Base MK IV Roadster with several options. Body is Lamborghini Grigio Lynx w/ Audi Vesuvius Gray stripes. 25th Anniversary FFR wheels. Seats and interior by Intatrim.
    Gen1 Coyote w/ Comp Cams & Cobrajet manifold. Tremec TKO 600 w/ a midshift kit. 2015 IRS w/ 3.73 Torsen diff. FFR Headers, Gas N Pipes, Power steering & power brakes.
    Nov 2018
    Michael,
    The coyote kit I purchased came with four, I only needed two. Not a very scientific answer, but the best I got.
    - Flip
  11. Thanks Hacksaw84 thanked for this post
  12. #11
    Jul 2020
    Are quick jacks powder coated to mat black? Also, are rear quick jack/bumper grommets from FF?
  13. #12
    Nov 2018
    Mad,
    The quick jacks are powder coated, but I wouldn't call it an absolute matte/flat. There is some sheen, but very minimal. Not sure if you can tell from the closer picture. I placed it on a white background hoping to give you a better idea. As for the grommets, I think I got them from **********.
  14. #13
    Jul 2020
    I send you a PM. Please check your inbox. Thanks!
  15. #14
    Aug 2018
    I would like the two side mirrors, heater controls defrost valve tubing kit, power steering hoses, unknown mounts and shifter boot. My zip is 04043. Let me know total and postage charges. We can use PayPal.
  16. #15
    Nov 2018
    RR,
    PM sent.
    - Flip
  17. #16
    Nov 2019
    Pm sent on Steering Wheel Center
  18. #17
    Nov 2018
    Salty,
    I didn't get the PM. I still have it if you'd like the part.
  19. #18
    I could use the rear grommets and fan switch. Pm sent.
  20. #19
    Jul 2019
    Quick jacks, mirrors and rear grommets still available? pm sent
  21. #20
    Nov 2018
    CRN,
    PM sent.
