Installed the E-Stopp parking brake to keep the cockpit clean. 2A7B1890-2693-445A-9993-5F04AEB1E3A3.jpgDE8379E4-837C-443B-BD48-9F1CFADA7E42.jpg62BC37BA-BD42-4A62-BCB1-D01A9A6355C5.jpg
Just bought one. Going to see if there is a place to mount it in the rear to avoid having the cables run into the console.
If you really want to eliminate the cables you can add some Tesla e-brake calipers.
I can pull them off my Roadster. Nope, that one has cables.......old tech.
If I can eliminate the cables running into the console area, it will keep things a little simpler there with the wiring harness and shifter cables all sharing space at the rear. But from Brd.Prey's pictures, that is a pretty neat installation. I just received the E-Stopp yesterday, so I'll poke around under the car and see if there are other options.
