0
If you're using a cell phone to take your pictures, there is a setting to disable the "orientation" bits in the image data. The rotation is displayed in some apps, like this forum, based on that data. If you use the approach described here, it won't be a problem:
https://thefactoryfiveforum.com/show...tures-in-posts
