Likes Likes:  2
Results 1 to 12 of 12
Thread: Front Wheel Hub Nut Size
    Jun 2020
    SoDak
    I need to pick up a socket for the hub nut on the front wheel hub, anyone know the nut size off hand?
    Thanks in advance
    I used 1 3/8, but 35mm is often quoted.
    https://thefactoryfiveforum.com/show...l=1#post277945
    Simi Valley, CA
    I bought a 36 mm socket at a local auto parts store for about $10. They are also available on line at Amazon, Jegs, etc. for about the same price. Keith HR #894
    Jun 2020
    SoDak
    Thanks RoadRacer & progmgr1
    Jun 2020
    SoDak
    1-3/8" did fit my hub nut so I order a 35 & 36mm socket from amazon
    Senior Member Nigel Allen's Avatar
    South Australia
    using a vernier, measure the width between opposing flats of the hexagonal nut, if it measures as 36mm, then you need a 36mm socket.
    ugh that sucks. 1 3/8 is very close to 35mm.. but I've seen just as many report needing 36. ¯\_(ツ)_/¯
    Dreamer j33ptj's Avatar
    Wassenaar, The Netherlands
    The hub nut is from the 89-97 Mustang, a search for that nut size showed up as 36mm
    RJ
    Jun 2020
    SoDak
    Thank you RJ...
    I have a 35 & 36mm coming (should be here tomorrow) which the 35mm will not be wasted since the hub nut on my 55 F100 using a coil over IFS suspension kit from TCI are 35mm.
  10. Likes j33ptj liked this post
  11. #10
    Jun 2020
    SoDak
    Just received the 35 & 36mm sockets....my hub nuts are definitely 36mm.
  12. Likes j33ptj liked this post
  13. #11
    lol, so weird, sorry! Mine was 1 3/8 or less than 35 there's my credibility gone out the window
  14. #12
    Jun 2020
    SoDak
    Quote Originally Posted by RoadRacer View Post
    Not at all, I appreciate any insight...I never mind picking up additional tools. I do a lot of vehicles and neighbors seems to borrow a lot of tools so I'm fine adding to the inventory of tools.
