Results 1 to 4 of 4
Thread: Hydraulic Clutch
    Jun 2020
    SoDak
    Hydraulic Clutch
    For those running a slave cylinder clutch set up in their 33 HR, are you just using normal Dot 3 Brake fluid in the system or what are you using?
    Senior Member Blade's Avatar
    Apr 2019
    Dunlap Tenn
    I have a Hydramax clutch system. The instructiobns said to Use only DOT3 or DOT4 high temperature non-silicone brake fluid. I hope that helps
    arrived July 18th 2019, first cart in Feb. 2020
    BluePrint Engines 383CI TKO600 GM Street&Strip
    Ridler wheels 17x 8 front 20 x 10 rear
    Toyo Proxes 245/35-17 front
    285/25-20 rear
    0mm offset finished Jan 2022
    Jun 2020
    SoDak
    Quote Originally Posted by Blade View Post
    Yes, it does... I was planning on using DOT 3 since that is what I'm used to in my 69 Austin Healey but I haven't done a hydraulic system in a modern car yet so wasn't quite sure if that was still the go to fluid. I'll look into DOT 4 as well but you confirmed my thinking.
    Thanks much
    Senior Member nuhale's Avatar
    Jun 2019
    Gurnee, IL
    DOT 3 is fine for a hydro clutch. If you have 4 left over from the brake system go for it. Non-silicone. Heat isn't really a issue with the clutch.
    MKIV #7275 Acquired June 2019 (2010 partial build), Gen 2 Coyote by Forte w/TK600- PRO 5.0 - McLeod RST twin Clutch-QT Bell, old style IRS, 8.8 3.55 Rear, Gas'n Headers/Pipes, Power Steering, Hydroboost by Forte, Breeze Roll Bar, Heated Seats, 17" halibrand w/ Nitto G2, Maradyne Fan Controller, Paul Proe Vent Kit, Russ Thompson Signal w/ FTP- Received June 2019/First Start April 2020/Go Cart May 2020/Legal September 2020/PAINT BY SPOTLIGHT CUSTOMS JAN 2021
