Likes Likes:  3
Results 1 to 5 of 5
Thread: Scavenging heads for dry sump
    Charm City
    FFR 818r Instagram biknman69
    • Ernest Hemingway
  2. Thanks Rob T thanked for this post
    Likes mikeb75, Kurk818, Jetfuel liked this post
    Sgt.Gator's Avatar
    Bend, Oregon
    We are just about to do this to my STI cam covers but the space is very limited by the STI frame rails. This may be a better solution. Thanks!
    Owner: Colonel Red Racing
    818R ICSCC SPM
    Bowling Green, KY
    Those are a trick solution.
    Jan 2018
    Jake from IMS here
    Never cross'ed my mind to use these to drain out of the heads but no reason they wouldn't work. The newer angled units im making could be swapped from side to side so the outlet faces down, Effectively drivers side head seal on passenger side etc. If you see something else that can be done to make them work let me know
    [email protected]
    Charm City
    Here is another item I've found for yawl that you might find useful a Oil Pump Delete Cover:
    https://www.facebook.com/DRC-Race-Cr...9320362912734/
    • Ernest Hemingway
