Likes Likes:  2
Results 1 to 6 of 6
Thread: Halo Lights
    Halo Lights
    Haven't torn up enough stuff yet so I have lately become infatuated with the round Halo Lights. As I research it I find that there are varieties that can double as turn signals. Question is, how much of a modification or how many modifications will be neccessary to convert the kit supplied Headlight to a Halo light with the turn signal bei9ng connected to the Halo. I hope you can tell I don't havea clue where to start. Perfect world wouold be that I can buy the Halo beams and plug them into the existing harness.
    Jun 2018
    North Vancouver, BC, Canada
    Bill, I don't see how the wiring would be any different than the LED lights that now come with the kit. They do get wired a bit different than the old lights but it isn't difficult. I have no idea if its a concern or not but I was wondering how well the turn signal would actually show up when the headlights are on. In any case, if you have a certain model in mind I would be happy to have a look at them and help with the wiring if you need it
    Gen 1 '33 Hot Rod #1104
    Thanks Steve, just starting to try to figure out what I am looking for
  4. Likes FF33rod liked this post
    Jun 2018
    I think Jeep 7" work. Like these (some of them seem to come with Canbus modules now too which you wouldn't need) perhaps https://genssi.com/7-inch-halo-proje...eadlights-set/
    Are you changing from incandescent or do you have LED already? if you don't have LED, you may have to change the turn signal and hazard flasher relays as well.
    Simi Valley, CA
    LED headlights with halo and yellow turn signal
    This is what I got from Amazon:
    https://smile.amazon.com/SUPAREE-inc...s%2C221&sr=8-1
    I will use the halo lights as Daytime Running Lights, so they will be powered whenever the ignition is on. The only trick is that the yellow turn signal will only go on if the halo is also powered (i.e. both powered, not either). Also, you will need the LED flasher mentioned above. I got this one, also on Amazon: https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    HTH Keith HR #894
  7. Likes shmelty liked this post
  8. #6
