Results 1 to 39 of 39
Thread: Extra Accumulated Parts
    Senior Member EZ$'s Avatar
    Feb 2014
    San Ramon, CA
    OK, so I've been putting this off, and the parts list keeps getting bigger so, here goes.
    Let's start with the items that will be free for just the shipping.
    P1010171 by Rick Paul, on Flickr
    FFR part # 11080 drive pulley
    P1010153 by Rick Paul, on Flickr
    Under dash braces
    P1010170 by Rick Paul, on Flickr
    Hood Pin Set TAKEN
    P1010183 by Rick Paul, on Flickr
    Diodes used in Russ Thompson turn signal wiring TAKEN
    20201220_143128 by Rick Paul, on Flickr
    Valve stems from Halibrand wheels
    20201220_142332 by Rick Paul, on Flickr
    Radiator cap 16#
    Rick
    Feb 2014
    San Ramon, CA
    Now for the parts with prices.
    P1010148 by Rick Paul, on Flickr
    Conical air filter New SOLD
    P1010152 by Rick Paul, on Flickr
    Unbent side vents Just shipping
    P1010172 by Rick Paul, on Flickr
    Heater control cable and control valve Just shipping
    P1010174 by Rick Paul, on Flickr
    Lokar shift boot (boot only, no trim ring) $ 8.00 SOLD
    20201221_132006 by Rick Paul, on Flickr
    Lokar brake handle boot (boot only, no trim ring) $ 5.00
    P1010175 by Rick Paul, on Flickr
    FFR brake handle boot SOLD
    Rick
    Feb 2014
    San Ramon, CA
    P1010176 by Rick Paul, on Flickr
    Ron Francis VSS pigtail for T5 $ 5.00
    P1010178 by Rick Paul, on Flickr
    3 pcs. Carbon fiber pattern switch covers Just shipping
    P1010179 by Rick Paul, on Flickr
    2 pcs. FFR single pole switches $ 4.00 total SOLD
    P1010177 by Rick Paul, on Flickr
    Zinc Radiator anode $ 8.00
    P1010184 by Rick Paul, on Flickr
    Auxiliary fuse panel $ 5.00 SOLD
    P1010185 by Rick Paul, on Flickr
    Fragola #12 hose clamps 3 packs SOLD
    Rick
    Feb 2014
    San Ramon, CA
    20201220_143025 by Rick Paul, on Flickr
    Plastic radiator hose "T" filler (FFR) $ 5.00
    20201220_142933 by Rick Paul, on Flickr
    Fuel tank filler hose $ 5.00
    20201220_142848 by Rick Paul, on Flickr
    Wilwood remote brake reservoirs (as pictured) SOLD
    20201220_142716 by Rick Paul, on Flickr
    FFR battery hold down kit $ 8.00
    20201220_142402 by Rick Paul, on Flickr
    Serpentine drive belt $ 7.00
    P1010181 by Rick Paul, on Flickr
    Battery cutoff switch (from FFR) $ 15.00 SOLD
    Rick
    Feb 2014
    San Ramon, CA
    P1010180 by Rick Paul, on Flickr
    FFR shift lever - will come with rubber boot (damaged), and the trim ring w/ hardware $ 20.00
    P1010182 by Rick Paul, on Flickr
    FFR throttle cable $ 10.00
    P1010186 by Rick Paul, on Flickr
    Manual steering shaft fitting $ 10.00
    PB300106 by Rick Paul, on Flickr
    PB300107 by Rick Paul, on Flickr
    Starter motor for 302 SOLD
    P1010168 by Rick Paul, on Flickr
    Holley fuel filter $ 10.00
    Rick
    Feb 2014
    San Ramon, CA
    P1010167 by Rick Paul, on Flickr
    Breeze large tube fuel pickup with hose $ 45.00 This was $95 new from Breeze
    P1010169 by Rick Paul, on Flickr
    Holley mechanical fuel pump $ 70.00 This is a $ 115.00 at Summit
    P1010165 by Rick Paul, on Flickr
    Oil dip stick $ 25.00
    20201220_143401 by Rick Paul, on Flickr
    20201220_143426 by Rick Paul, on Flickr
    Oil pan with pick up tube for 302 $ 30.00
    Rick
    Feb 2014
    San Ramon, CA
    20201221_131857 by Rick Paul, on Flickr
    Polished tall valve covers for 302 SOLD
    032 by Rick Paul, on Flickr
    Original style Shelby valve covers fabricated by me SOLD
    20201221_132053 by Rick Paul, on Flickr
    Fortes 1/2" valve cover spacers (Minor clearancing marks on outside edge. $ 90.00 These were originally $160.00 from Fortes
    All items are plus the freight. I can accept PayPal. Please respond in the thread only, no PM's. If you have any questions about any of the items, also please ask them in the thread.
    Thanks for looking, and Merry Christmas!
    Rick
    Rick -- PM sent on the FFR brake handle boot.
    Dec 2018
    Hudsonville, MI
    I’ll take the fragola #12 hose clamps
    Coupe Kit Delivered 11/10/23
    Bridgeville,Pa
    PM Sent Filter, Cut off switch, Starter, both sets of valve covers
    Feb 2014
    San Ramon, CA
    Dave, the FFR brake boot is yours. I'll get back to you with the shipping cost. PayPal works best for me.
    MSumners, They're yours. I can probably send them in a small padded envelope. PM me your address.
    Dean, I'll figure the best way to ship all this, and get back to you with a cost.
    Thanks guys.
    Rick
    Feb 2020
    Chicago
    ill take the shift boot!
    Feb 2014
    San Ramon, CA
    jiriza84641, It's yours. I'll need you ship to address. PM it to me.
    Rick
    Sep 2020
    Seconds on “ Original style Shelby valve covers” (just in case deal falls through).
    As an aside, would OP share sources for components, maybe I’ll try my hand at fabrication. I found a source for the decals, but would need the other components.
    Feb 2020
    Chicago
    PM Sent.
    Feb 2014
    San Ramon, CA
    Skip, I'll make a note. These were standard stamped steel valve covers, old style, not the new tall covers. I was going to use them with the 1/2" valve cover spacers, but I ended up going a different way. One of the covers had the filler neck that I welded an angled extension onto, and the other cover I had to drill a hole for a second filler tube, cut and weld the pieces for the tube, and I made a baffle for the tube I created to match the other cover. I'll have to look up the paint color that I used. Breathers were just stock, I think from Summit. I just looked for black breathers, and then placed the decals. I wish I could say that I had come up with this, but I owe that to Bill (2FST4U). He did a write up on it quite a few years ago, and I just copied his.
    Rick
    Feb 2014
    San Ramon, CA
    Skip, I found my notes from when I did those covers. The tubing that you'll need is 4130 tube with a wall thickness of .050. You need two pieces 3" long with a 15 degree angle on one end, and one straight piece 2-1/2" long. Need to drill a new breather hole. The gussets are fabricated from .050 thick sheet, and weld to the tubes and the covers. Cover the old PCV hole with left over sheet metal. The color is Rustoleum HiTemp flat gray in a rattle can #248904. Hope that helps. Still haven't gotten confirmation on the sale, so I'll keep you posted. I'm sure that with Christmas I may not hear back until the weekend or early next week.
    Rick
    Are those rectifier diodes designed to allow the current to flow in only one direction? If so, I could make use of a pair of them.
    I wanted to hook up a reminder beeper to my t/signal switch, and am thinking they may be the answer to prevent back-feed.
    Should I PM you my address, as to the postage required? Prefer not to post my address on a post.
    Thanks.
    Feb 2014
    San Ramon, CA
    Bill, I'm so totally devoid of knowledge when it comes to electronics I cannot answer that question! If you PM your address, I can get you a cost to get them to you. You're welcome to the entire bundle. There are four still in the original package, and I believe two that were fabbed up in the wiring. I really wouldn't know what to do with them if not directed by someone else!
    Rick
    Thanks.
    Quote Originally Posted by EZ$ View Post
    Short answer is yes, the diodes are designed to allow current to flow in a single direction. The silver band indicates the blocking direction where power can pass through the diode across the black portion and through the band, but not the opposite. Think of the band as a dam.
    This may help:
    https://www.google.com/search?q=rect...obile&ie=UTF-8
    Feb 2014
    San Ramon, CA
    Thank you Dave!
    Rick
    Sounds like what I need then, thanks!
    Sep 2020
    Thanks EZ$ for the info about fabricating the valve covers.
    Feb 2014
    San Ramon, CA
    Bill, I responded to your PM.
    Skip, No problem.
    Rick
    Future Mk4 builder/owner
    Harleysville, pa (near Philly)
    I am interested in the heater control switch but would like a little more information. Do you have a part number? If it can fit in a Small rate box Or an envelope I would be interested. Thanks.
    Feb 2014
    San Ramon, CA
    Tim, as I mentioned in response to your PM, I'll try to find the part numbers, and get a more detailed picture, and post it here.
    Rick
    Feb 2014
    San Ramon, CA
    Tim, Here are some more pictures of the parts with the bags that have the parts numbers on them. Not sure if they are Vintage Air part numbers or FFR.
    20201227_103625 by Rick Paul, on Flickr
    20201227_103634 by Rick Paul, on Flickr
    20201227_103657 by Rick Paul, on Flickr
    20201227_103715 by Rick Paul, on Flickr
    Hope that helps. Let me know and I'll see what kind of box I can get these in, and I'm sure the other switches should fit as well.
    Rick
    I could use the hood pins, FFR single pole switches, and the fuse panel. Shipped to 66856. Thanks, Dale
    Feb 2014
    San Ramon, CA
    Dale, I was just heading out to ship some parts, and get estimated postage on some others. I'll box them up, and get back to you with a cost.
    Rick
    Sorry, just sent a PM back and didn't realize you asked all questions to be put on here instead.
    Btw, the links to the additional pics above, didn't go anywhere. Said there is an error when I click on it. ��
    Feb 2014
    San Ramon, CA
    I'm not sure why you can't see the pictures. They appear in the thread when I bring it up. Don't worry about responding here or by PM. I'll see it either way.
    Rick
    Feb 2014
    San Ramon, CA
    Tim, Here are some more pictures of the heater control cable. One shows the end, and the other two show the push/pull action that operates the valve. I've sent a PM with cost for the shipping.
    20201229_115659 by Rick Paul, on Flickr
    20201229_115732 by Rick Paul, on Flickr
    20201229_115742 by Rick Paul, on Flickr
    Rick
    Feb 2014
    San Ramon, CA
    TTT
    Still some great parts available!
    Rick
    Senior Member bil1024's Avatar
    NY
    PM sent on oil pan / dipstick and adapter
    Feb 2014
    San Ramon, CA
    Bill, just responded to your PM. Need an address.
    Rick
    Feb 2014
    San Ramon, CA
    So I adjusted some parts costs, and added some notes. See if it changes your mind.
    Rick
    Senior Member gtaroger's Avatar
    Trenton Mi
    I'm intrested in the steering coupler. If it is 1 inch DD on one end and 11/16x 36 spline I will take it.Roger
    Feb 2014
    San Ramon, CA
    gtaroger, Let me check that out, and I'll get back to you.
    Rick
    Feb 2014
    San Ramon, CA
    gtaroger, Here's the view from the back side of the adapter.
    20210117_161139 by Rick Paul, on Flickr
    The entire unit OD is around 1"+. On the other side, the opening measures 11/16, and I counted 36 splines. It was the standard manual steering adapter that came with the kit. Let me know if it will work.
    Rick
