I started off with the decision that I needed to use the beefy 27 spline spindle from a 2004 JDM STI. When I couldn't locate any, I decided to break down and go with 2006 STI rear knuckles with the 27 spline axles and 5x114 wheels. Then I started thinking why not go full STI. So I went with the front STI knuckles and the 5x114 hubs, and I figured I'd go with the stock STI brakes all around. Worked out fine in the front. I easily modified the FFR upright adaptors, and I added 1/8" plates to each side to beef them up. I got stock STI rotors for about $25 and a very nice pair of rebuilt calipers for $368 from Rock Auto.
So now I'm trying to order the rear brakes. Got the rotors, no problem from Rock Auto. I go to order the calipers and all of a sudden, I have a problem. Out of stock at Rock Auto. Also out of stock at Autozone, Summit, 1A auto, Carparts.com, partsgeek.com, NAPA, Advance Auto, O'Reilly, Ebay, even Amazon. Nobody has them. I checked with my local dealer. The Subaru P/N's are 26692FE002 and 26692FE012 for the right and left calipers. I'm told they're Brembo calipers. I can order them for around $700 EACH. I went to the Brembo website, and for some reason, they don't list the STI brakes, nor do they cross to the Subaru P/N. They cross to similar Subaru P/N's, which look to be WRX parts. The rep at Summit called Powerstop, and Powerstop finally admitted they don't have any, and couldn't say if or when they might get any.
So, anyone know of a source of reasonably priced rear 2006 STI calipers? (either used or rebuilt)
OR, does anyone know what changed on the 2008 STI calipers? I hear they are similar but different.... I can get 2008 calipers.
