Results 1 to 5 of 5
Thread: WTB: Older Style Brake Reservoir
    Senior Member D02G's Avatar
    Mar 2019
    CT
    Looking for the attached older style brake reservoir. Or, just the cap.
    MK IV - #9586, Gen 2 Coyote, TKO 600
    BadAsp427's Avatar
    Greeneville, TN
    I have this one, it was from circa 2015. I mounted it, but never used it or put fluid in it. Yours for your offer and shipping if you want it.
    Carl
    Mar 2019
    CT
    Carl
    Hi Carl, Thank you for the response. Any chance you can measure the threaded opening? Do you know if that cap will fit on the other style that I have?
    Brian
    BadAsp427's Avatar
    Greeneville, TN
    Quote Originally Posted by D02G View Post
    Brian
    I just measured the opening and it is 1 1/4" I also took the top off of mine on my car and it threads in perfect, same size.
    Mar 2019
    CT
    Awesome. Thank you. I will Private message you my address and let me the cost.
