0
0
2015 Mustang GT Body Shell Rebuildable Clean Title !!
*****SOLD*****
For Sale 2015 Ford Mustang body shell and interior 24,000 miles. This car was involved in a collision where another car clipped the front in a glancing blow. THIS CAR HAS A CLEAR TITLE NOT SALVAGE. Title is notarized and ready to transfer. It was reported to CARFAX and it shows it was involved in a front end collision only. I have a copy of the CARFAX. I have removed the engine, engine cradle, exhaust including manifolds, transmission, driveshaft, front brakes, emergency brake handle and complete independent rear, brakes, wheels and tires to use on another project. In my opinion the Mustang can be repaired and become an excellent car again. The interior is immaculate black leather and complete except for emergency brake handle. The car appears good basically from the shock towers back. The paint is excellent and appears original. 3 airbags were deployed in the collision. The engine cradle and front frame horns appear to have taken the brunt of the impact. The car was flat bed towed from the collision scene to a storage building. No fork lift abuse !! It was always garaged prior to and has been indoors even after the collision. Components were removed by unbolting and not cutting with a torch. The hood, front fenders, front outer and inner bumpers were scrap and discarded. All remaining usable front end parts were removed and labeled and are included. These parts alone are worth money for resale.
Included:
2 Key fobs and hard key
Fuel system intact including in tank pumps
Brake lines intact and present except flex lines to calipers
Wiring intact with some minor cuts to front loom from collision
PCM intact and included (VIN sensitive)
Fuse box intact however mounts have damage
Factory A/C intact however compressor stayed with motor
Both lower side ground effects complete and present
All windows intact
Doors complete with gaps consistent and correct
ABS system complete with sensor wires attached.
Includes front spindles and struts, sway bar and mounts, dog legs, and lower control arms
Includes electric steering box
I constructed a roll around cart that the car is sitting on. It should be able to be pulled up onto a car carrier trailer with a suitable winch so bring it with your cash to pick up the car. Also bring tie downs to strap car to the cart as well as the trailer. Cart goes with the car.
This car is rebuildable either by using new parts, used parts or another complete car possibly damaged in a collision. If doing the work yourself you will need automotive repair knowledge. NOTE: The Mustang Gt model has very few changes between 2015 and 2020 models. You should be able to use most if not all the parts from your wrecked 2015 to 2020 car with a salvage title to rebuild this car with a clear title. Consult your Ford dealer to confirm.
Since this car was purchased by me as is I have no idea what systems are operational or effected by the collision. Car is sold as is no guarantee expressed or implied.
Car is sold as is. I am NOT parting it out !
Sorry no trades.
$ 5800.00
Call Wayne at 602 390 7834
Please do not email me via Craigslist I will not answer.
If you are really interested please call.
Photos to follow or see Phoenix CraigslistD9LxHV7kTgaSQkOmtZTHYw.jpglkkdmAMBTY60t4WevBI7nQ.jpg0NpZT99zTVCDtn%UBbI1GA.jpgoQQyX0jlQyqr0PpbhaA2Qg.jpg4Cnj89KtS4eNQALAAIwr%g.jpg8P9Jy9FNTGKQ9I0NyvrRaw.jpgfullsizeoutput_138b.jpeg9Vd%2bTlTz6NRw%+%oy8iw.jpgPZgWwmMrRqCFymwRCyuWQg.jpg
Reason: Add photos
This car has been sold. 1/15/2021
