Hi friends.
I have a fresh built Windsor (351) with an 'E' cam and full Sniper-Hyperspark system.
First start went well (just started, not run up to operating temp yet) but I need to set initial timing & I'm wondering if anyone has some personal insight.
I set static timing at 10° and disabled 'Idle Spark' control. This is the Holley prescribed method for first start, but Holley doesn't prescribe what to set static timing at. I believe 10° is too retarded as after 30 seconds of running, I started getting slight stall and a good flamed backfire from the exhaust. Holley uses 15° as an example only.
I have seen on the Holley forums that some people have initial idle timing set as high as 25°. That seems to be too advanced to me. The entire point in the process is to phase the actual timing to the Hyperspark ECU timing, allow engine to get to operating temp and then go to the next steps of break in.
What initial timing did you guys use with a similar cam with a 110° lobe separation?
