hi everyone i have a ford 33 i start the engine after a long time it's start and a few minute after it's stop an no electrical signal everywhere? what it happen any respons? the battery is a new one!
Last edited by prc31; 02-27-2021 at 01:04 PM. Reason: trouble after a long time not running
hi it had start engine and it stop suddenlly and no electrical response everywhere
Tell us what you have checked? Is the car completely finished or just a chassis without the body on?
You said the battery is good, do you have 12 volts at the starter solenoid and at the fuse box?
Are you using the Ron F. wiring harness?
Did you check the safety inertia switch (orangish / red under the dash).....meant to trip if the car ever rolls, kills the power.
Jim
