Results 1 to 5 of 5
Thread: after a long start engine run and after no elecrtical and engine stop
    Feb 2021
    hi everyone i have a ford 33 i start the engine after a long time it's start and a few minute after it's stop an no electrical signal everywhere? what it happen any respons? the battery is a new one!
    Last edited by prc31; 02-27-2021 at 01:04 PM. Reason: trouble after a long time not running
    Senior Member JOP33's Avatar
    Haslet, Texas
    Quote Originally Posted by prc31 View Post
    Will it start again after sitting or doesn't start at all? Fuse maybe? How long did it run? Enough to heat up and possible burn through an un shielded wire?
  3. Thanks prc31 thanked for this post
    Feb 2021
    hi it had start engine and it stop suddenlly and no electrical response everywhere
    Placitas, NM
    Tell us what you have checked? Is the car completely finished or just a chassis without the body on?
    You said the battery is good, do you have 12 volts at the starter solenoid and at the fuse box?
    Are you using the Ron F. wiring harness?
    Jun 2020
    SoDak
    Did you check the safety inertia switch (orangish / red under the dash).....meant to trip if the car ever rolls, kills the power.
    Jim
