Thanks Thanks:  8
Likes Likes:  146
Page 4 of 6 FirstFirst ... 23456 LastLast
Results 121 to 160 of 220
Thread: Meyer 818 build in Tampa Bay Area
  1. #121
    Very Nice, Next milestone is the go-kart stage. We auto-crossed our go-kart for a whole summer to sort things out.
    Something to look forward to. This is a video on ar first day auto crossing our 818.
    https://thefactoryfiveforum.com/show...l=1#post174470
  2. #122
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    You just put a big smile on my face on this cold yucky winter day. Thanks for sharing! Spins up really fast it seems, at least compared to my hulking 3.0 motor... lightweight flywheel??? I still want to get over there some day, finally got shot 1 of 2 for covid (yah I'm an old geez).
  3. #123
    Aug 2018
    In due time old geez we'll get there...
    March 11 and I'll get my second shot...
    Jet...come on spring!!!
  4. #124
    Senior Member Scott Meyer's Avatar
    Palm Harbor, FL
    Seats and getting closer to go-cart
    Lots happening as the COVID fog lifts from my brain (I was unfortunate and tested positive last month). Almost fully recovered but good enough to be back in the world and working on the 818 again with Liam!
    My next job is fabricating seat brackets for our EBay seats! Been talking to Rob (roadrashrob) daily as we share our build and ideas, and he has some nice flat frame adapters from Corbeau, which I planned to copy...so we made a cardboard template first to get the size of our seat base and sliders.
    68C49A80-778F-4C6F-97AE-0899486545C5.jpeg 6471B808-8A6C-4D46-9B50-60D578D3B7F1.jpeg
    As we started looking for the best spot for the seats, and how to attach them to the frames, I made a mental leap that we really just needed flat extensions with studs that we can blind mount from up top and bolt underneath. Break out the Lincoln Mig welder I’ve not used in 13+ years...
    Here are the rails in process and after being finished. Our sliders are 14-3/8” on center. So centerline the 1-1/2” x 1/4” flat stock, measured off the trans tunnel and then drilled and clecod in place. Up drill and weld cap hex head bolts to the flat stock, up drill the frame of the 818 and rinse/repeat,
    675D9896-3E6A-438A-AE83-05A06B0A57E4.jpeg 86553189-5FE9-42EA-9DA7-22831801F51B.jpeg 40B8CA2E-3E84-4C7C-AF26-E96EBE28A119.jpeg D7399A2B-C791-4E3B-AEB6-1D040EC04C0E.jpeg
    After some weld splatter burns, I called it a night. Will confirm the seat position on the flat stock today and drill for the seat slider mounting.
    818 "S"pyder delivered 11/27/20, using 2007 Impreza 2.5l NA donor. Work mostly being done by my son Liam...body work and paint being done by dad (that's me)
    MK3.1 #6583RD, built from 2008-2019, sold 11/2011
  5. #125
    Senior Member DSR-3's Avatar
    San Jose, CA
    I think you will want to raise the front of the seats.
    I placed a 1.25" (or 1.5"?) square tube across the front 2 slider holes, and thru-bolted the rear slider holes to the frame crossmember.
    As I recall, you can go that far back and still not run out of slider travel forward before the seat hits the frame.
  6. #126
    Palm Harbor, FL
    We sat on the seats inside the car and they are perfect flat on the floor for us. Liam is 6’-4” and I’m 6’-3”... we need all the headroom we can get when the soft top is up. The passenger seat will be installed where it fits (all the way back) and will not be able to slide forward due to cross brace on the 818 frame. Drivers seat will have a few inches of travel.
  7. #127
    San Jose, CA
    Ah, you're the tall guys...
    At 6' I feel maxed-out, so I have no idea how you will fit. I do have different seats, but they all kinda look the same from here.
    No doubt not the first time you've had to deal with these things so I wish you luck.
    I've always seen the short cockpit and low rollbar as the biggest misses in the car.
    Great progrees on the build, and congrats' on survival!
  8. #128
    Palm Harbor, FL
  9. Likes mcamera liked this post
  10. #129
    Palm Harbor, FL
    Seats are both mounted, new shifter (k-tuned) and custom 818 shift knob are installed...and our tires arrived today from TireRack
    AF9170DD-64F2-4A9F-A47F-11D5F346B11E.jpeg 86B4ED13-A72F-499A-97D2-2DBD5B976DBD.jpeg 0B8A2A57-6003-4E92-A6D7-274BC91A6EBC.jpeg
  11. Likes jbs72697, AZPete liked this post
  12. #130
    Feb 2018
    Lexington, KY
    Hey Scott, I hope everything is going well. I was wondering if you had similar issues with the LED's that you found on Ebay. Mine look dim and uneven. None of the red markings on the gauges show up, the needles are poorly lit, and overall the numbers are not sharp. Mine only worked well in the 2 small screens at the bottom of my gauges.
    Pitch black, brightest the gauges will ever be
    Dark but with some background light, closer to real world driving on the highway
    Stock cluster
    818C w/ 07 WRX 2.5 Turbo, 5spd manual
    Delivered 10-29-2020
    First Start 3-27-2021
    First Drive 5-12-2021
    Street Legal 6-23-2022
  13. #131
    Palm Harbor, FL
    Meyer818 Go-Cart
    Michael,
    I've not noticed the same things you were not happy with, but I also haven't sat in the completely dark garage and played around with it yet.
    We achieved limited go-cart status this week. My wife was home and didn't want us driving on the street so the chassis moved under it's own power in and out of the garage. 1st and reverse worked!
    I'm also starting to prep the body panels for fitting this weekend...remember now how much fun and itchy the fiberglass work is!
    Meyer818_front_hinges.jpg Meyer818_pass door.jpg Meyer818_taillights.jpg Meyer818_rear grill.jpg
  14. Likes Bob_n_Cincy, jbs72697, STiPWRD, mcamera liked this post
  15. #132
    Palm Harbor, FL
    Preparing for Panel mounting...and PAINT
    Well, there comes a day, when you have to decide on the paint color! Liam and I had pretty much decided on this last fall after we had the choices narrowed down to 3-4 colors, and then on my way to work one day...this passed me on the highway. I work for Honda and had not really seen this color up close yet, it looks stunning on the NSX, and will really pop on the 818S!
    We will be using Kirker Automotive paints, and I just ordered all of my supplies today from AutoBody Toolmart. I have painted 3 cars in my past (one of which was the 3-color F5 Cobra in 2010), plus my Experimental Airplane...so this is old hat for me.
    Here is the actual color we got:
    This week we started bringing all of the body panels upstairs and prepping the back side, by spraying them with Raptor Liner...saw this on another builders blog videos (David Robinson) and thought it was a great idea. Takes away the "kit car" feel on the visible back side of the panels.
    Originally I wanted to get the car assembled, and do some shakedowns, get it registered with State, etc... and then do the paint later this Fall...but I'm leaning towards the "Get it done" now!
  16. Likes DSR-3, Hobby Racer, jbs72697 liked this post
  17. #133
    Aug 2020
    New Paltz, NY
    Looks great guys! I love the Raptor liner on the rear of the panels, and will definitely do the same. Color will look amazing, but my skills are no where near the point I would paint it myself... We're definitely leaning towards Vinyl wrap to start, and then perhaps paint some day.
    You definitely helped us a lot by being slightly ahead of us in the build, but sharing a lot of common build practices that I really admire. Thanks for that!
  18. #134
    Palm Harbor, FL
    Body fitting almost done 4/11/21 Update
  19. Likes Shawn818c, Jetfuel, jbs72697, AZPete, aquillen liked this post
  20. #135
    Aug 2020
    New Paltz, NY
    Quote Originally Posted by Scott Meyer View Post
    This one is just going to be a teaser...we’ve got the car registered for the Ohio Import Faceoff next Sunday- April 18th...
    "Import Challenge"? I know MA was originally a British Colony, but not sure cars from there are still considered imported... :-)
    Incredible progress recently! We're just back from two weeks in FL, and in "Meyer" progress, I feel like it was two months! Good luck at the challenge. Your Gelcoat definitely looks good (in pictures). ;-)
  21. #136
    Palm Harbor, FL
    Thanks Rob, and I was down for the count most of this week with my business trip, college visit and 2nd Vaccine shot!
    Well the donor is a Subie (Japan = Import) and the car is now considered an exotic by Liam’s piers, and definitely the most “built” car of his group of friends! The gel coat is “good from a far, but far from good”! Learned from building the Mk. 3 cobra over a decade ago, get everything to fit and drive it for a bit, then do bodywork with everything assembled and aligned, and finally pull apart for final prime and paint.
  22. #137
    Senior Member AZPete's Avatar
    "Import Challenge" I took my 818 to the Scottsdale Cars & Coffee a few times and was told the first 2 times, "this is the American car section. You should move to the European car section." Each time, I explained that the chassis is from Massuchusetts and the car was built right here in Scottsdale, they walked away confused.
    The Subaru guys were all over it with questions and photos.
  23. #138
    Aug 2018
    Well... I guess Liam put you under the gun Scott...
    The first car show I went to (coffee and doughnuts with cops at the Indianapolis motor speedway) the L.E.O's awarded us "best import"...yep go figure
    Jet
  24. #139
    aquillen's Avatar
    NW Indiana
    I did one (the only local) show late last fall once I was rolling. No category for a car like this, so went with the engine... "import". Would rather call it American but to go for a take home award I guess you have to make the rules fit your build.
  25. #140
    Palm Harbor, FL
    Jet and Pete,
    Good to hear from you both! I think we will make it and be happy with the results. I was working on the “trunk lid” tonight and Liam was fitting the drivers side door. He managed to get the passenger door “passible”, but not perfect. He’s self taught like myself and I’ve really been trying to let him learn on his own lately!
    BTW, I’ve posted on Facebook, that he has decided to pursue Engineering at Ohio University this fall! We toured the campus last week and he was really happy with the environment and city. We are going to submit his housing acceptance this week which locks in his acceptance! 6 weeks until high school graduation!
    66D67886-A1A7-48DA-BBD1-6DBA12B310F5.jpeg E6F3A8A1-18A6-458F-AD91-D53DB8AD55B4.jpeg
    62CD52C6-DAB5-44F4-968C-FB7EC11780D0.jpeg C0B1AAE8-F561-459F-B495-13BE60D061BD.jpeg F51BC48B-96C3-4823-ACB4-6A5B99B702A8.jpeg
  26. #141
    Palm Harbor, FL
    A visit by another 818 and super guy!
    There has been an Art Q sighting in Dublin, Ohio today. He was gracious enough to drive over from Indiana and show off his 818C that is crazy with little details that he’s customized and grafted in from other production cars.
    Right now he’s helping Liam sort through some of his taillight wiring issues (Art thinks it’s crossed wires).
    98394269-2390-4138-9226-47C392599D63.jpeg D93BFBBD-A83F-4E78-9800-0C6E50219A72.jpeg B908FFA4-8D6D-45AF-B3EF-6F0EB1DC1A64.jpeg 82917847-378E-40D3-A022-5EA2B184E2B6.jpeg 6D613B3B-E9FA-47E6-B70C-F05B9EDDE23C.jpeg
  27. Likes DSR-3, AZPete liked this post
  28. #142
    Aug 2018
    Really guys????
    Here I am itching for a long drive.....
    Jet
  29. #143
    Palm Harbor, FL
    Import (Tuner) Face Off
    Well, it’s over! I had to punch out early as the super loud sound/bass vehicles and guys revving until the limiter kicked in was getting to be too much for me...
    But we trailered the 818 to it’s first show while still under construction. Was able to drive it on and off trailer and around the raceway. Tons of interest and questions about the car. Top question was “What is it?” And with the engine cover off, 2nd top question was “what is that engine”...when we answered a Subaru Boxer people were stunned. Pretty cool.
    C2BAD5C0-8FFA-4294-898A-F15CD27E9F2D.jpeg FE8C509C-90C6-4B63-BB5C-9ED8ABF4B603.jpeg B0454939-8AB4-4D47-9F5B-10AB186CAC45.jpeg
  30. Likes fletch, Jetfuel, DSR-3 liked this post
  31. #144
    Palm Harbor, FL
  32. Likes aquillen, jbs72697 liked this post
  33. #145
    Palm Harbor, FL
    Time to restart the body work progress…
    Last Friday Art and JetFuel stopped over and took Liam with them up to see Jamie who’s also almost done with his H6- 818S.
    Good news Art/Jet, the kitchen remodel is done for now! Just waiting for the countertops to be measured and installed (probably won’t be done until late July).
    So earlier in the week, Liam got to meet one of his hero’s- Travis Pastranas…and is volunteering this weekend at the Southern Ohio Rally Race where he is competing for Team Subaru.
    And we are back to the nasty sanding of the bodywork prep!
    897B7FF7-3623-49C2-A29C-4461AF09D1C7.jpegBEE36D5B-89E2-49E1-83D6-C6983B0185B4.jpeg5161AA7C-D210-4934-BB10-31BD72558257.jpeg9D543EF1-EFD2-4BC5-933F-9E3D7CDBDA7A.jpegE11F100F-DDCD-458A-A833-AD6783511C88.jpeg
    Also got to talk with Jeff Kleiner today! We go way back to my roadster build in 2008-10…and he confirmed some of the next steps and highly recommended Slick Sand high build polyester primer surfacer. I had the used this on my roadster back then which led to the conversation when and he told me he’s been in contact with the now (new) 3rd owner of my project and he lives near Chicago.! I looked up the guy “Dave” (dpariso) on here and the car still looks great! Appears some improvements to the intake and appearance (roll bars, side pipes and cam covers) were also done since I sold it to the Coast Guard officer in Florida back in 2011. The paint still looks great which reaffirmed my skills in painting a car!
    https://thefactoryfiveforum.com/album.php?albumid=1226
  34. Likes Frank818, aquillen liked this post
  35. #146
    aquillen's Avatar
    NW Indiana
    Of course I'd like this post, I'm in it . Congrats on kitchen progress as well as the car. Liam added much fun to our outing, great kid with a great future.
    Entire trip was a hoot with Jet and I leaving Indy early morning and back at 11pm. Two of these cars on the road together draws a lot of ogles. I had over 800 miles from NW Indiana and back, Jet most of that as well - both cars run like they were born for it. My 45 year old daughter after a spin that weekend said "gee dad, it's just like a real car".... now that is what I would call a heartfelt compliment.
  36. Likes Hobby Racer, Kurk818 liked this post
  37. #147
    Palm Harbor, FL
    Body work…is a slow process
    Realizing we have not posted an update in well over a month. Body work continues and I’m a perfectionist so it’s slow. And hot…and dusty. Not happy with the gaps from Factory 5 I’m fixing all of these issues, extending the trunk lid and just about done with the engine cover and the CF skinning.
    77A80857-D60A-42A3-BE5B-3413CB30FEFA.jpeg A439B3FB-A241-4C81-9E09-B2E3E9885CD2.jpeg923859F1-38E7-4E8C-B80A-7BC6E31F7A03.jpeg3A5F1024-3B20-4DF4-B171-C5E2709D197C.jpeg
  38. Likes DSR-3, DJWalker liked this post
  39. #148
    Aug 2020
    New Paltz, NY
    Awesome and scary at the same time. You know what you're doing, and it's a lot of work! Bodywork is not in my comfort zone. Will definitely be looking to you for guidance as we approach that point.
  40. #149
    San Jose, CA
    Liking the skins! (but not the hood pins) Nice gap-fill too, that will be an obvious plus once finished. My biggest fill was at the bumper/trunk lid.
    What's your color(s) plan?
  41. #150
    Feb 2019
    Houston, TX
    Quote Originally Posted by roadrashrob View Post
    already answered above
  42. #151
    Palm Harbor, FL
    Thanks for the repost on my colors. It’s now a custom color blend of the Sunkist Pearl (was too yellow) and Candy Red (Chianti to be exact) that I achieved with help from Kirker’s tech support. By doing several spray outs on the speed shapes got the color as close as possible to the Acura Thermal Orange Pearl.
    We don’t like the hood pins either…and have a plan in the works. Don’t want to spoil all of my tweaks so rest assured we are only keeping what’s necessary to attach the F5 soft top. Everything will be color coordinated!
  43. Likes DSR-3 liked this post
  44. #152
    Palm Harbor, FL
    Happy Labor Day
    It’s been a crazy month of August and needless to say Zero work on the 818. Spent a week in SoCal for work, and then we moved Liam to Ohio University for the start of his Freshman year in Engineering! It’s been very hard to get motivated to work on the car without him, but staying in constant contact via iMessage and sharing my recent progress…yes I’ve returned to the darn bodywork!
    Since we have a NA motor (EJ253), the recess in the trunk was just a deep dish bowl, and the thought of a fake vent wasn’t sitting well with Liam. So, I made a composite core and fiberglassed it in!
    AED5599C-560A-4BB1-88AC-18720FCA6F7E.jpeg8E5001CD-67EF-4C72-80CE-8AAC83FE8AB0.jpeg2FBF8BE6-DD86-4416-AF82-B6C64ADEC4B2.jpegC579A840-FF86-4924-8954-E2D88E5BB1E3.jpegB08735C3-BBB5-4AAD-BBCC-445035C98528.jpeg
    And have spent the last day applying and sanding off the Rage body filler…
    5FC5CE46-8B77-4A64-824D-99EAFA944ED4.jpeg59922C31-E225-43BC-A42F-CAB26E5E71D0.jpegB14F3DCE-5303-46C0-9303-5BF93E9C6F28.jpeg31E3430C-C890-4BEA-8144-4CDD13AA5391.jpeg
    The end result now makes sense and looks great!
    Next up is to finish the engine cover, and then last is the front hood…and we may be ready to remove the panels for primer by mid-September!
  45. Likes Frank818, DSR-3, Bob_n_Cincy liked this post
  46. #153
    Hey Scott!
    I was just thinking about you guys a few days ago and wondered how it was going! Thanks for the update...now get back to your sanding
  47. Likes Bob_n_Cincy liked this post
  48. #154
    aquillen's Avatar
    NW Indiana
    Lookin' better all the time ! Tell Liam I said "hi".
  49. #155
    Palm Harbor, FL
    Primer is going down…
  50. #156
    Aug 2020
    New Paltz, NY
    Love the carbon fiber!
  51. #157
    Palm Harbor, FL
    The little touches…
    I had one online vendor argue with me that this word was trademarked by one OEM manufacturer, but there are currently at least 4+ exotic cars called the …Spyder.
    So here is a glimpse at some of my custom touches before I lay down the base coat.
    0279E203-272A-4BD8-B7D2-A9542CB23764.jpeg45657A96-5407-42CF-9D63-BE8BBF95EDB0.jpeg87F7FF20-70B3-4A95-9BBC-1DB1A3A4A3E3.jpegCBB72A23-07C0-48B1-B06D-8E77A7494C54.jpeg
    Maybe one more sneak peak…and we may not be doing Orange anymore…one person on here knows the real color but I have bribed him with Oban Scotch to be quiet!
  52. Likes fletch liked this post
  53. #158
    Bolton, Ontario, Canada
    Pretty sure you can use a trademarked name as long as it is for something you are making for yourself. A supplier could get in trouble for making something for a customer. I like it! I had the president of Ferrari/Maserati Canada drop by when he saw me working on what he thought was a Dino....it was a replica. He said "Ferrari doesn't like it when people do that".
    Oh, and even Factory Five had a Spyder!
  54. Likes J R Jones liked this post
  55. #159
    Aug 2020
    New Paltz, NY
    That was a bribe? Darn. I drank so much of it I forgot the color you told me! :-)
  56. Likes Shawn818c liked this post
  57. #160
    Palm Harbor, FL
    All I can share is it’s one of these colors?!?! We’ve been spraying out many test colors to find the one Liam likes the best and I can accurately recreate! I’m not very consistent with multi-stage pearls…so that has heavily weighed on my decision.7057AB8D-4D53-482D-9070-1FAD65B1D278.jpeg
    There was one critical item I almost forgot to cut and test install before paint!
