If you have did you or how much did you trim off the block plate and bottom of the housing? Also did you run into any interference with the frame when installing? There are a few older posts that mention there might be interference. I’m aware trimming may negate the SFI cert for certain racing situations. Pictures are appreciated if you have them. Thanks!
