Results 1 to 23 of 23
Thread: Cobra brakes ordered from RockAuto for 2012 rules
    Senior Member johngeorge's Avatar
    Nashua, NH
    Hi gang,
    Here is my order from rock auto for the front calipers and front disks for the 2012 rules:
    Code:
    1998 FORD MUSTANG COBRA 4.6L 281cid V8 FI (V) DOHC
     		Part Number 		Part Type	Price EA	Core EA 	Quantity	Total
    CENTRIC		12061045 (120.61045)	Rotor		$ 48.79		$ 0.00		1		$ 48.79
    CENTRIC		12061044 (120.61044)	Rotor		$ 48.79		$ 0.00		1		$ 48.79
    RAYBESTOS	FRC10603		Caliper		$ 57.89		$ 10.00		1		$ 67.89
    RAYBESTOS	FRC10604		Caliper		$ 57.89		$ 10.00		1		$ 67.89
    Rotors link: http://www.rockauto.com/catalog/rafr...&parttype=1896
    Calipers link: http://www.rockauto.com/catalog/rafr...&parttype=1704
    http://johngeorgeracing.com
    Kirkland, WA
    I assume you have the caliper brackets already? Are you going to run the Carbotech XP10 pads?
    Tony Nadalin
    2022 SOVREN Championship
    2018 SOVREN Big Bore Champion
    2012 ICSCC ITE Class Champion
    Nashua, NH
    These calipers are the same ones that Jim ordered and those came with caliper brackets.
    I usually run Carbotech XP10 front, XP12 rear.
    Last edited by johngeorge; 12-14-2011 at 12:57 PM. Reason: corrected pad compounds.. was backwards
    Kirkland, WA
    Great price for calipers with brackets. I may have to try the XP12 in front as I run the XP10 all the way around and have had no issues. Does Carbotech still offer a 10% discount?
    Tony Nadalin
    Nashua, NH
    Whoops, my bad.. I got them backwards, XP10 front, XP12 rear
    Nashua, NH
    My parts already came in and the calipers have the brackets with them!
    Also, the Carbotech front brake pads part # is CT412, they gave me a 7% NASA discount
    Apex, NC
    great info...thanks
    Kirkland, WA
    Quote Originally Posted by johngeorge View Post
    Just ordered the CT412 in XP10 and got the 7% (seems they dropped from 10% in 2009).
    Tony Nadalin
    Apex, NC
    JG,
    Are you keeping the same Master's? If so, which ones are you using again?
    2012 NASA-SE FFR Champion
    2011 NASA-SE FFR Champion
    Race page - http://www.mh-motorsports.com/race.shtml
    Team Facebook page - http://www.facebook.com/pages/MH-Mot...s/264814350042
    Nashua, NH
    Yes I'm keeping the same masters.. 13/16" front, 5/8" rear (for t-bird calipers use 3/4")
    Atlanta, GA
    Which brake lines did you go with?
    Nashua, NH
    Quote Originally Posted by ksamson View Post
    The ones that are on the car didnt change them (think all hard lines are 3/16.)
    Apex, NC
    JG, are you keeping the same NO2 lines too? If so, where do you hide the bottles?
    Nashua, NH
    no need for NO2 with 320HP!
    Apex, NC
    Oh so true. Heard back from trick flow yet?
    Nashua, NH
    I was able to try out the new brakes and tried to set brake balance front/rear. Good part is I know fronts work real well, bad part I was not able to lock rears. I ordered a bigger master for the front (7/8", I had 13/16", will keep the rears the same 5/8") to fix my issue and will try again.
    Also modified the brake pedal ratio and got 6:1 out of it by cutting 3/8" off the 4cyl pedal. The feel is great! no longer a stiff pedal!
    Apex, NC
    John,
    Which 7/8" MC did you order? I am getting all of my parts together to go with the Dual Master setup.
    Nashua, NH
    Marty, not sure which dual master you have.. might not fit for your application
    In any case, I bought this one http://www.summitracing.com/parts/WIL-260-10374/
    Apex, NC
    Right now I have a stock single master so it's all changing.
    Apex, NC
    New front calipers are in
    These suckers are huge
    Kirkland, WA
    I'm running a S10 dual master, not changing with the cobra brakes
    Tony Nadalin
    Apex, NC
    Hmmm... There were no brackets shipped.
    Apex, NC
    Quote Originally Posted by mhoward1 View Post
    OK, The other box had all the left side hardware with it. It seems the right side was shipped with the Caliper only and no hardware at all.
