Results 1 to 3 of 3
Thread: 3/4 " master brake cylinders
    Feb 2018
    Does anyone know the nuts size for mounting the master brake cylinders to the pedal box. There are 2 for each cylinder. I am installing a clutch cable vs hydraulic clutch, so I only need 4. Been all through the PedalBox component boxes and the Wildwood brake box with no luck. Thanks
    I don't have one in front of me to check. But according to the Wilwood instruction sheet, the studs on the front of the pedal box are 5/16-24.
    Feb 2018
    Thanks Paul.
