Any words of wisdom?
I have the FFR headers for the Coyote engine.
Bottom bolts are tough to reach, can’t even get the two center bolts started.
Any special tools or do I need to find someone with longer fingers😁
Ray
Ray
Here's a link to the "fun" it was on #9365... it's really not too bad!
John D. - Minneapolis 'Burbs
Thanks John for pointing out the obvious. Reuse some of the existing studs.
Ray
I have the Daytona coupe with Gen 3 Coyote. What worked for me on the header bolts is this:
I had to remove them after engine install as the headers will not fit into place with the factory header studs in. Also, header bolt holes did not all align to allow for exact fit - soooo:
I widened the bolt holes as needed in the headers using a drill and file. Install the header studs back in with header and gasket in place. If you have any trouble getting the header studs back in, then use flange head M10 x 1.25 x 30mm bolts. Use whatever tools you have that will fit. I used a variety of rachets, tight space wrenches and whatever could fit. As mentioned by another thread there is at least one that allows only the open end of the wrench with 1/8 turns at a time. Its a PITA job and caused a lot of bad language!! In the end I spent many more hours than I thought on this.....Just like on most other aspects of this project - good luck!!
