Thanks Thanks:  15
Likes Likes:  110
Results 81 to 120 of 214
Thread: fletch & son's build thread
    Senior Member AZPete's Avatar
    I'm trembling with all that clamping to granite in the kitchen! If I did that . . . when my wife was home . . . I'd be locked in the cold garage without the sour dough.
    Those brake line mounts are very cool. I wish I needed some, but I'm past that stage.
    And, you creatively solved the radiator drain problem that many of us had.
    Nice work and thanks for posting it. Happy 2021.
    Senior Member fletch's Avatar
    Dec 2018
    Just outside ABQ, NM
    LOLLLLL!!!! Sounds like a story in need of sharing.
    Dec 2018
    Cabinet scraper
    Somebody mentioned that cleaning up the parting lines was easier/quicker/cleaner with a cabinet scraper. "What's a cabinet scraper?", I asked.... google. It's a piece of metal with a burr on it that you drag over wood to smooth it. Like a plane, but pulled instead of pushed. Instructables.com helped show me how to make my own.
    Old hacksaw blade and old 3/8" drive extension to create the burr. Press down hard and slide forward and rightward to create the burr on the "Starrett" side.
    Seems to work pretty well so far.
    Two-handed operation is best, but I needed a hand to operate the camera.
  4. Likes Frank818 liked this post
  5. #84
    Dec 2018
    Curb feelers
    While tooling around the neighborhood a few days ago, Isaac hit the wrong pedal during a turn ... the turn went from a 90 to a 270 ... fortunately he entered a driveway, then hung the right front wheel over the curb. It could have been much worse. He blames his shoes... and inexperience, which shows a considerable level of self-knowledge and humility for which this dad is most grateful. We'll be looking to get some track time at our local speedway in the next few months, so both of us can learn our way around a mid-engine, rear wheel drive car. After all, it's our first ... in so many ways.
    The damage:
    The souvenirs!
  6. Likes Bob_n_Cincy liked this post
  7. #85
    Quote Originally Posted by fletch View Post
    Tiger drylac ral3020 - https://www.lvppaints.com/RAL-3020-1...-Up-Paint.html
  8. Thanks fletch thanked for this post
  9. #86
    Mar 2014
    Hingham, MA
    The damage:
    The souvenirs!
    Shortly after my sons got their driver's licenses I sent them to 3-4 day professional drivers schools. One went to Bondurant in AZ where he droves Vipers and formula Mazdas. The other to Jim Russell at Mt Tremblant where he drove Formula Mazdas including the car Lance Stroll learned in. Both learned a lot about driving and car control but perhaps more importantly respect for cars and driving.
  10. #87
    Bolton, Ontario, Canada
    We've gotten pretty good at draining & refilling the coolant system ... because we've had to fix so many leaks.
    One of the royal pains was the radiator outlet. It was trapped inside the radiator frame. In order to open the drain we had to remove the radiator mounting brackets at the top, then shift the radiator up and forward.
    So, we needed a solution. More JB-Weld and a few fittings along with a ball valve. We drilled a hole through the handle so we could safety-wire it in the closed position.
    That is a really good idea! I partially drained my system to plumb in a heater, and getting it to drain without it hitting the frame and splashing everywhere was really annoying. Then trying to put the plastic plug back in to stop the flow after partially draining it finished making the mess. So I think I will fully drain it and do something like you did.
    Rick
  11. #88
    Dec 2018
    Sequential turn signals & DRLs - first attempt
    With some guidance from Bob_n_Cincy, we put an old Sparkfun Pro Micro (arduino-type) board to use sequencing the turn signals. Here's the breadboard setup - very crude, but functional.
    And here's a link to one of the crappiest videos I've ever taken. Enjoy!
    https://youtu.be/JYH6xlT72Wo
  12. #89
    Dec 2018
    Back to zero - and that's a good thing!
    Thanks to K3LAG we're now at zero!
    The soldering job is what I call "good enough" - not ideal, but plenty fine for our purposes. I work in aerospace and have seen some awesome hand work. I can't reproduce what others do regularly, and that's just fine. It takes hundreds of people with different skills to make a satellite work. Seems to be the case with this car too. Thanks again K3LAG!
    Also "deleted" the airbag light while we were at it. That was simpler - two snips with a pair of nippers to remove the LED.
  13. #90
    Aug 2020
    New Paltz, NY
    K3LAG: Sent you a PM as I'd love to do the same!
  14. #91
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    I'd trust you to do soldering for me....
  15. Thanks fletch thanked for this post
  16. #92
    Dec 2018
    Powder coating
    Major thanks to JimLev for loaning me his powder coating setup.
    Before (I forgot to take this pic before coating the first pair of brackets. Too eager to get started!):
    After:
    These pieces barely fit in the oven.
  17. Likes Rob T, AZPete, Bob_n_Cincy liked this post
  18. #93
    Dec 2018
    Clutch
    Shiny bits.
    Resurfaced flywheel and new Exedy clutch installed and waiting for a transmission.
  19. #94
    Dec 2018
    Isolating the parking brake switch
    This is probably something that very few people will need to do. Our Arduino implementation for turn signals and DRLs requires an input from the parking brake so we can disable the DRLs when the parking brake is applied. In the OEM design, the parking brake switch grounds its input to chassis when enabled. In our version, the parking brake switch will operate as an input to the Arduino and we'd rather not ground the Arduino to chassis. Doing so would make it much more susceptible to any spurious currents running through the chassis from all sorts of other sources. So we need to isolate the switch electrically from the chassis. Here's what we did.
    Here's the unaltered switch. The spade terminal is the "hot" or active side of the circuit. The little brass point (1 of 2) on the left side makes contact with the spade terminal. The current flows all the way up the shaft, then back through the spring, to the mounting bracket which is grounded through the parking brake frame.
    Next, we ground off the end of the shaft and threw away the brass pointy part, then assembled all the parts we'd need. A tiny bit of shrink tube, a 6-32 nut, a ring lug, and JBWeld (in the end we used JB Kwik because we're impatient.) We also adapted a binder clip to compress the spring during future steps.
    Putting female threads in a hole is called tapping. I know you use a die to put male threads on a rod. Is that called dying?
    Missed a couple photos here. The steps are: 1) Assemble the switch with shaft & spring, and hold with binder clip. 2) Put a short section of shrink tube on the shaft. 3) Put ring lug on shaft. 4) Screw nut onto shaft. 5) Slide shrink tube down to the nut and heat it until shrunk (shrinked?) 6) With ring lug slid toward the nut and over the shrink tube, wrap a narrow strip of masking tape around the shaft to keep the JB Kwik from getting on the shaft past the shrink tube. 6) Apply JB Kwik to the top of the nut, then slide the ring lug down, keeping a narrow thickness of JB Kwik between the ring lug and the nut. 7) After the first cure time, trim any shrink tube that is above the ring lug. This will keep the plunger from traveling far enough to allow the ring lug to contact the spade terminal plate.
    Theory of operation: The shrink tube keeps the ID of the ring lug from contacting the plunger. The JB Kwik keeps it from contacting the nut. Instead of the spade terminal grounding to chassis, it contacts the ring lug and completes the circuit through it.
    After the first cure time, add another layer especially at the end where the plunger rod protrudes from the nut. Add the wires and it looks something like this.
    Here's the finished product from two angles.
    It's a good idea to confirm isolation using an ohmmeter throughout the process. It will keep you from making mistakes.
  20. Likes Bob_n_Cincy, DSR-3, AZPete liked this post
  21. #95
    aquillen's Avatar
    NW Indiana
    So what is more fun... assembling something handed to you or designing solutions and making yourself. (No wrong answer here actually)
  22. #96
    Dec 2018
    I like doing both, at different times. I've always enjoyed and learned from taking things apart and putting them back together. My wife swears that's how I fix most of the broken things around our house - just disassemble, then reassemble. She's got a point that several times, I've not found a root cause but the process seems to fix whatever was wrong - poor electrical contact or maybe just mechanical slippage that's improved by the rebuild.
  23. #97
    Feb 2019
    Houston, TX
    Good solution there. I'm using an arduino for all of my lights and blinkers too, but sine my electric parking brake is controlled by the arduino I got to skip this step.
  24. #98
    Dec 2018
    Transmission rebuild
    First and of highest importance is to say thanks to Rob T to helping us out in a major way. He made us a fantastic deal on his used gear set. Thank you, Rob. We are very grateful.
    One weird thing we noticed was the difference between the 5th-reverse selector setup of the two main shafts. Rob's followed the FSM exactly. Ours was missing a few parts.
    His version appears to have an actual synchro for reverse where ours was missing that completely. Oh well, maybe this will make for smoother shifts into reverse?!?
    Rob's pinion gear was missing two teeth so we needed to swap in our old pinion gear & shaft. We beat on the nut & used plenty of heat, but still couldn't get it off, so...
    The case is prepped and shafts go in.
    Checking backlash & finger painting with the prussian blue.
  25. #99
    Dec 2018
    Completing the assembly
    The plan is to put it back in tomorrow night. Then we'll need to decide whether to get back to go-kart right away or to finish a few of the electrical clean up items we were working on. Most likely, we'll get it running again because driving it around the neighborhood is way more fun than cleaning up wires.
    I should also say how grateful we are for Hindsight's LSD thread here: https://thefactoryfiveforum.com/show...ions-with-pics
    We would probably not have attempted the rebuild without it.
  26. Likes Shawn818c, Jetfuel, DSR-3 liked this post
  27. #100
    Fenton MI
    how much did you pay for the gear set (if you don't mind). I have a 2nd trans with a blown 1st gear I would like to rebuild
    Factory Five 818c #456
  28. #101
    Leesburg, VA
    Quote Originally Posted by Shawn818c View Post
    I've got a gear set from an 03 wrx sitting around collecting dust (I only needed the trans case), PM me if interested.
  29. #102
    aquillen's Avatar
    NW Indiana
    Setting pinion - crown mesh - glad you went for it ?
  30. #103
    Dec 2018
    Aside from feeling swoll, the benefits were probably nil. The shims as supplied with Rob T’s driven shaft were fine. I suppose finger painting with Prussian blue has its therapeutic benefits as well.
  31. #104
    Dec 2018
    Back in
    Transmission went back in with little fanfare... just in time to return the borrowed engine hoist. I think we had it for 18 months or so. Working on a car project is a great way to make friends!
  32. #105
    Dec 2018
    Fresh powder!
    We're about a month past skiing season in New Mexico. You're probably thinking, "I thought New Mexico was the desert?!? Isn't it way down south?!" Yes, you're right. It's in the desert and it's pretty far south. However, altitude trumps both of those. When you're at 10,000 feet above sea level the snow flies and tends to stick around. But enough about that...
    The REAL fresh powder is in the Fletch garage.
    Nuts on a string
    This was a case of stars aligning or what have you. JimLev loaned me his powder coating setup and I started to imagine all the uses for it. We had the transmission out so the rear suspension was pretty easy to get to... I even powder coated my coffee mug.
    And then... as my wife can attest, I can't leave well enough alone. The painted brakes didn't match the powder coated suspension parts. Plus, they were chipped due to a few wheel removal/reinstall cycles. Of course, that won't suffice. So we stripped and powder coated them too.
    Right now I'm eyeing the front A arms and steering rack... Isaac's not happy with me. It's been weeks since he's been able to do burnouts in the neighborhood...
  33. #106
    Dec 2018
    Steering column
    A few weeks ago roadrashrob asked about our steering situation - our use of an NRG quick disconnect with the OEM column, etc. Rob, this is my attempt to answer your questions. If I miss the mark, let me know and I'll post a follow up. Unfortunately, we won't be reinstalling the column for another week or two so all these pics are on the bench.
    Here's our column setup in profile. The tips of the stalks are about 3.5" from the center line of the steering wheel. Not ideal, but better than where we started.
    Various stages of disassembly, showing the NRG hub and the adapter.
    Before and after of the adapter. I don't know for sure if this was a FFR-supplied item. It looks a bit different from others I've seen on the forum. It came with the kit when we bought it second-hand.
    One consequence of all the stack up was to push the wheel too close to the driver for comfort. We compressed the column by pinching the larger OD tube in a vice and sliding the narrower tube & shaft toward the driver. We then extended and lowered the mount point using some plate steel, 1/4" pipe and 5/16" bolts. An unanticipated benefit of this arrangement was that it allowed us to shift the wheel to the left toward the center of the driver's body. We haven't fabbed up our dashboard and recognize the drop may cause issues with finishing around the upper part of the column... a problem for another day.
  34. Likes Santiago liked this post
  35. #107
    Aug 2020
    New Paltz, NY
    Thanks Fletch! Exactly what I was looking for. Should help other builders as well.
  36. #108
    Dec 2018
    More on steering (moron steering?)
    My original post showing the adapter mod & column in place.
    https://thefactoryfiveforum.com/show...l=1#post434237
  37. Likes Frank818 liked this post
  38. #109
    Dec 2018
    Track day
    You wouldn't know it from our build thread, because I've not done a good job keeping up with all our work, but we're planning a track day in the next week or two. This will be our first shakedown of sorts and we're looking for input. What would you do? What would you test? What would you measure?
    The car will eventually be more of a daily driver, but we'd like to iron several things out first.
    Top on our list is brake bias. We've got the Subaru ABS system installed and it works well. A few hard stops from 30-35 mph have produced quick, but even stops. We plan to disable the ABS and dial down the pressure to the rear wheels with the proportioning valves until it's closer to neutral. Then re-enable the ABS. We don't have our final wheel & tire setup so this will be a preliminary brake balance.
    What else should we be considering?
    If I understand correctly, we may be sharing the track with others, but should have enough space to do more or less whatever we need to. There's a skidpad, a road course and an oval.
    Thanks for the input.
  39. #110
    Senior Member Rob T's Avatar
    Woodruff, SC
    Fletch: If you are going to Sandia, be careful and take it easy. It's a fun track and the people there are great, but there is very little run off room. Trust me, I had a close encounter with a tire wall there when my brakes failed. Lots of turns with no real place for the brakes to cool. I think my mistake was running with some "old" brake fluid. One thing to do for sure is to make sure your fluid is fresh.
  40. #111
    Dec 2018
    Thanks for the reminder Rob. We plan to ease into it. Not really running the track all out or anything near it. Probably just running at auto cross speeds checking various attributes of the car.
  41. #112
    Dec 2018
    Wiring
    I spent a LOT of time tidying up some of the shortcuts we took late last year to get to go kart. One big area was the wiring. Initially we planned to locate our single fuse box in the front of the tunnel facing the passenger footwell. While trying to clean some of the old wiring up, I decided it was too much trouble to keep it there. So I moved the fuse box up above the dash frame and called JimLev for a battery cable extension. It was so much easier to work with the fuse box in this position. There's still a bit of a mess up in the dash, but we're not done yet. Still to be done: head unit/radio + speakers, seat heater wiring, auto AC panel from Subaru (trying to modify this to drive the Vintage Air temperature control), Arduino for turn signal/DRL control + SSM to CANBUS conversion to display ECU info to the head unit.
    Before:
    After:
    Very happy the headlight wiring is in and tested, the cruise control wiring is in (not tested), and we have the harness to the rear bumper fabbed nearly ready to install.
  42. Likes Bob_n_Cincy liked this post
  43. #113
    Dec 2018
    Front suspension refresh
    Remember how I said the powdercoating tools from JimLev were calling my name, begging me to be used on the front brakes and suspension, those parts that had countless nicks in the paint from our wayward wrenches? Well, I broke down and tore the front apart. A full brake teardown, tie rods spun off the steering rack, pressed bushings out of LCAs... well not actually. Those darn bushings wouldn't come free even after I'd used all manner of heat and pressure (plus a big hammer). You can't bake those things at 400 F. So, what to do? Ebay!
    Before
    After
    I didn't take any photos of the completed brakes or steering setup, but they look much nicer and aren't going to mind a brake fluid splatter or incident abuse from a dropped wrench.
  44. Likes Bob_n_Cincy liked this post
  45. #114
    Dec 2018
    Fuel pump inspection
    We purchased some foam blocks for inside the gas tank to reduce sloshing. While installing that, I took a look at our fuel pump given the recent issues others have experienced with the pump output hose coming loose. Here's what I found:
    All is still well as we originally built it. We cut the OEM pump bracket and inserted a piece of steel. We used two self-tapping screws to secure the assembly along with a healthy dab of JB Weld. A stainless hose clamp keeps the pump in place. So far so good!
  46. Likes Bob_n_Cincy liked this post
  47. #115
    Dec 2018
    Go kart - part 2
    And finally, we're back to go kart stage once more. So much good stuff. A transmission that shifts easily into 2nd, front wheel wells, STI LCAs installed in the outer holes so zero rubbing of the front tires. Some insulation in the rear firewall... too much to remember.
  48. Likes Bob_n_Cincy, Rob T liked this post
  49. #116
    Aug 2020
    New Paltz, NY
    Where did you get your fuel blocks from? They are on my list, but there seems to be a lot of variation in price in what I’ve seen
  50. #117
    Dec 2018
    Quote Originally Posted by roadrashrob View Post
    https://www.speedwaymotors.com/Fuel-...ach,52163.html
    Bought 6, only needed 4.
  51. #118
    Dec 2018
    Alignment
    Finished our first alignment today. Still on donor wheels & tires. 17x7 +42 offset w/ 225/45 R17s all around.
    Used this fantastic thread. https://thefactoryfiveforum.com/show...s-for-the-818S
    And this reference: https://thefactoryfiveforum.com/show...l=1#post126682
    Final specs
    Ride height 4.5"
    Rear:
    Toe: 3/16" total
    Camber: -0.5 deg
    Front:
    Aluminum LCAs in outer mounting holes
    Toe: 1/16" total
    Camber: -1.0 deg
    Caster: R 5.1 deg, L 5.5 deg
  52. #119
    Dec 2018
    Tuning
    This car’s going to be a handful.
    2.5L from 2006 WRX
    TD04-19T turbo and Grimmspeed EBCS
    91 octane
    Our tuner also remapped the DBW pedal inputs to make it much smoother at tip in. Very streetable—up to a point.
  53. Likes Rob T liked this post
  54. #120
    May 2020
    Looking forward to seeing it drive by me in ABQ sometime in the near future!
  55. Likes fletch liked this post
