Thread: SBF motor mounts, poly or solid
    Senior Member Joe Campbell's Avatar
    Idaho Falls, ID
    I have some old Energy mounts that gave up the ghost, need a new set.
    FFR7859 - graduated 5/16/16; '11 Mustang 5.0 'vert; '93 Mustang Notch; '98 F150; 4760 build website; FFR-3144 rebuild
    Senior Member Fman's Avatar
    Jan 2020
    State of Jefferson
    I have a set of the FFR energy mounts that were modified by Mike Forte to fit a dart block. Not sure if this is what you are looking for?
    Member 7tvette's Avatar
    Sherwood Park, Alberta
    I would recommend going to poly for a street used car. I just switched my BMW M3 track car to solid bushing and engine mounts...I feel every pebble on the road.
    Troy
    " The journey is the reward" Chinese Proverb
    FFR Roadster #5380
    FFR Spyder GT #030
    Idaho Falls, ID
    I do have the Dart block, I'll PM you...
    Falmouth, MA
    I would also recommend the poly mounts for the street. I typically used the poly mounts but went with solid mounts on a 65 coupe build. I could feel every cylinder went it fired. Kinda neat though went you pul up next to somebody, blip the throttle and the whole car twists up!
    Apr 2021
    solid motor mounts are great on a track, but on a street car you will feel more than you may like. Also if you do install them its a good idea to start marking bolts/nuts, Vibrations from solid mounts love to shake parts loose.
    Idaho Falls, ID
    Good points, I'll stick with a poly set.
