Results 1 to 4 of 4
Thread: Starburst Wheel valve stems
    Feb 2020
    Chicago
    Hey all, I have the sunburst wheels and noticed once I got home my rear tire was flat. filled with air and could tell that the valve stem when moved was leaking air. Can you tell me what type of valve stem is on it? discount tire had mounted the tire and not sure if they can just replace this one or just replace all of them if there is a issue with the valve stems.
    Thanks.
    Here is one valve stem from the company that makes starbursts, sells pretty cheap.
    https://www.americanrebelmfg.com/pro...age/valve-stem
    Feb 2020
    Chicago
    AC Bill, sorry for the confusion they are the Sunburst not starburst wheels.
    Feb 2020
    Chicago
    ISSUE SOLVED, the valve is not proprietary, it is a basic stem and just need to use a short one.
