Results 1 to 2 of 2
Thread: Koni shock alert
    Huntsville, Al
    Koni shock alert
    http://www.factoryfive.com/whatsnew/.../ksupdate.html
    Official KONI Shock Recall Notice I wanted to take a moment to let you guys know about a potentially serious matter that requires your immediate attention.
    Recently we received a report from a customer regarding a KONI shock absorber that had failed. This is the only incident of a broken KONI shock that we have received. We immediately obtained the part from the customer and forwarded it to the guys at KONI. It was quickly determined by the technical guys at KONI that the root cause of the failure was due to a cold weld. KONI and Factory Five Racing, Inc. are taking immediate action to replace any affected parts in the field.
    The potentially affected shocks are in a small range of about 125 customers and were delivered in FFR kits and parts sales AFTER February 2010. We have identified the potentially affected lot numbers and are asking you to check your shocks for the following batch numbers:
    Part Number: 30-1720, Date Code: 07-2010
    Part Number: 30-1721, Date Code: 07-2010
    Part Number: 30-1721, Date Code: 13-2010
    Senior Member Gopher's Avatar
    McHenry, Illinois
    Are these the single or double adjustable shocks?
    Anniversary Special,Dart Aluminum 427, AFR 225 outlaw heads,Howard Cams,Hillborn stack injection,Liberty Gears prepedTKO600, Five Link, ISIS Wiring,8.98 @151 with no power adders Photo album HTTP://photobucket.com/anniversary-car
