Results 1 to 9 of 9
Thread: Free Stuff - Just Pay Shipping
    RJD's Avatar
    Northern Virginia
    Super Moderator
    Ray's Avatar
    La Mesa, California
    What is the ID on the air filter where the hose clamp is?
    Ray
    RJD's Avatar
    Northern Virginia
    Quote Originally Posted by Ray View Post
    Ray
    Hi Ray,
    There doesn't appear to be an ID on it, but it's the filter FF5 ships with the complete kit.
    RJD's Avatar
    Northern Virginia
    Ray
    Hi Ray,
    Super Moderator
    Ray's Avatar
    La Mesa, California
    What s the Inner Diameter of the filter at the opening?
    If it will close to 2 1/2 inches I’ll take it.
    Sorry, I wasn’t very clear.
    RJD's Avatar
    Northern Virginia
    Ohhhh.....that ID, LOL. Looks like it is 3 1/2"
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Thanks. That’s going to be too large for what I’d be using it for (muffler on my shop-vac.)
    Thanks again,
    Ray
    BadAsp427's Avatar
    Greeneville, TN
    I would love the Fuel Filter...
    RJD's Avatar
    Northern Virginia
    All yours.
