Thanks Thanks:  15
Likes Likes:  95
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 121 to 160 of 198
Thread: Blade's 33 build
  1. #121
    Senior Member Blade's Avatar
    Apr 2019
    Dunlap Tenn
    I received the Tenhulzen alignment tool today. Can someone please share the specs I need for toe. I'm still in the body shop,but looking at the wheels it looks like I have a toe out issue.
    arrived July 18th 2019, first cart in Feb. 2020
    BluePrint Engines 383CI TKO600 GM Street&Strip
    Ridler wheels 17x 8 front 20 x 10 rear
    Toyo Proxes 245/35-17 front
    285/25-20 rear
    0mm offset finished Jan 2022
  2. #122
    Jun 2018
    North Vancouver, BC, Canada
    good luck
    Gen 1 '33 Hot Rod #1104
  3. Likes theidlemind liked this post
  4. #123
    Apr 2019
    Dunlap Tenn
    body,roof,doors and trunk lid got their last coat of primer today. last primer coat.jpegprimer on roof.jpegOn monday a light sand with 320grit and a wash before paint. So close. I just finished the seats. I added the breeze mounting kit and sliders from amazon. Love the way they came out. Will post pics this weekend. The combo gave me almost 4" of travel.
    285/25-20 rear
  5. Likes shmelty, 33fromSD liked this post
  6. #124
    Apr 2019
    Dunlap Tenn
    https://www.amazon.com/dp/B07DPT17CT...roduct_details the link to the sliders if you are interested. I mounted the sliders to the seat and then mounted the Breeze kit to the sliders. Only 4 holes required in the seat frame. The fiber board insert really firms up the seat. I could totally tell the difference. The Breeze components come raw, so get some paint on soon or they begin to get some surface rust. The components are top notch. I'm 6'3" and have my seat all the way against the waterfall. With these sliders I can not only reach my dash switches better, I can change seating positions on longer stints. seat 8.jpgseat 7.jpgseat 6.jpgseat 5.jpgseat 4.jpgseat 3.jpgseat 2.jpgseat 1.jpg
    285/25-20 rear
  7. Likes FF33rod, RoadRacer liked this post
  8. #125
    Apr 2019
    Dunlap Tenn
    The guys at the body shop asked how I was attaching door panels. I said,"I don't really know". I have seen them attached with screws, but didn't really want to do that. They suggested black double sided tape. Good idea but what if I want to remove some day. I suggested earth magnets, they nodded knowingly.....so I bought some small .260 and some large 1.250. the large ones will hurt you. they claim one will hold 110lbs. was contemplating gluing a thin metal plate to the lip of the door for the magnet to attach to, these would get paint and clear. I guess I'm wanting you guys to wade in on this. The panels are flat and the door has some contour,I made those bends and the panels sit pretty flat. The arm rest will be attached to the thick steel door bar, that will also hold the panel. So, what do you think???
    285/25-20 rear
  9. #126
    Jun 2018
    Want a bit more finished look than the screws and since one of my panels don't fit anyway I'm building my own. Hagan has various components for this and I will be using their door clips for fiberglass
    https://www.haganauto.com/product_p/dobptkf.htm
  10. #127
    Apr 2019
    Dunlap Tenn
    20210625_134759.jpg20210625_134749.jpg20210625_134739.jpg20210625_134733.jpg20210625_134717.jpg
    It has been a long process getting into the booth , but it finally happened today. These pics are before clear. The clear is being sprayed as I type. Will post after, probably Monday. the color is :
    285/25-20 rear
  11. Likes RoadRacer, FF33rod liked this post
  12. #128
    Apr 2019
    Dunlap Tenn
    Well I'm suprised. Here are the after clear pics. 5 coats of clear. Attachment 149876Attachment 149877Attachment 149878Attachment 149879Attachment 1498805242.jpeg
    285/25-20 rear
  13. Likes RoadRacer, FF33rod liked this post
  14. #129
    Sep 2019
    Hi Blade,
    When I click on the attachments in your latest post I get this error message "Invalid Attachment specified. If you followed a valid link, please notify the administrator"
    Andy
    33 Hot Rod with Deluxe Grill (32) Hood & sides, Bike Fenders, Hard Top, AC, Power Windows, Electric Power Steering, 306 Ford Small Block - roller cam, aluminum heads, Eldenbrock intake & carb, T5, Moser 3 link, Arrived 5/6/20.
  15. #130
    Simi Valley, CA
    Quote Originally Posted by e36m3 View Post
    Hi Blade,
    Andy
    I had exactly the same issue on 6/25, so I sent an email to the admin as directed. No response, and the links still don't seem to work? I understand that this is a minor issue in the big scheme of things, but I would like to see these photos.
    Keith HR #894
  16. #131
    Jun 2018
    I'm pretty sure the admin can't fix it, the poster needs to redo the post making sure the attachments work (right format, correct size)
  17. #132
    Apr 2019
    Dunlap Tenn
    Thanks for advising me. Let me try this again. The problem could be at my end. 5245.jpeg5242.jpeg5241.jpeg5241.jpeg5300.jpeg20210629_090030.jpg5345.jpeg5346.jpeg5347.jpeg5350.jpeg
    the first pics are in the booth after 5 coats of clear. the second set is after putting on the roof temporarily so they could cut and buff the car.
    285/25-20 rear
  18. Likes j33ptj, FF33rod, JimLev, peterh226 liked this post
  19. #133
    Looks Fantastic!
    16+ FFR kits and counting!
  20. Thanks Blade thanked for this post
  21. #134
    Apr 2019
    Dunlap Tenn
    some progress pics and a question. How does the inner door latch go together? inner door latch.jpgThe spring doesn't seem to be in the right place. gaps are needing final adjustment.doors on and ready for final adjustment.jpg finished with cut and buffboth doors cut and buffed.jpgdrivers door ready for install.jpgdoor close up.jpg
    285/25-20 rear
  22. Likes 33fromSD liked this post
  23. #135
    Jun 2020
    SoDak
    I just so happen to have an extra "assembled" inner door latch so I took a pic.
    Jim
  24. #136
    Jun 2020
    SoDak
    Also, in this link below under the 33 section there are instructions for the aluminum interior door handles
    http://www.factoryfiveparts.com/instructions/
    Jim
  25. Thanks Blade thanked for this post
  26. #137
    Apr 2019
    Dunlap Tenn
    thank you sir.
    285/25-20 rear
  27. Thanks 33fromSD thanked for this post
  28. #138
    Apr 2019
    Dunlap Tenn
    Had a good day today. Weather here in middle tenn was awesome. I got the trunk deck lid on and the whole thing works.trunk lid done.jpg The doors went back on without much hassle. both doors on and latches work.jpginside passenger door.jpg I like the aluminum inside door opener. I have read many threads about where and how to do rear view mirrors. Please give me your thoughts on this topic.
    285/25-20 rear
  29. Likes peterh226 liked this post
  30. #139
    Quote Originally Posted by Blade View Post
    Here you go. I love mine.
    https://thefactoryfiveforum.com/show...l=1#post447128
  31. Thanks Blade thanked for this post
  32. #140
    Apr 2019
    Dunlap Tenn
    power window connections finished.door contacts.jpgdoor contacts inside.jpg after much debate Zane(the painter dude) convinced me to paint the grill. It has enough clear to take a beating and still be able to cut and buff it.grill painted.jpeggrill 2.jpeggrill 3.jpeg
    285/25-20 rear
  33. Likes RoadRacer liked this post
  34. #141
    Apr 2019
    Dunlap Tenn
    My list of items to complete is getting short. I finished the dynamat in the cockpitstarting dyna mat install.jpgdynamat almost complete.jpgworking on dynamat.jpgseats in after dynamat.jpg
    Finished dynamat in trunk and added the stock carpet.trunk carpet 2.jpgtrunk carpet 1.jpgtrunk in dyna mat.jpg
    I didn't really like the ac controls plate so I cut it down, engine turned it to match the dash and mounted it to the dash. I am trying to not have anything hanging down heater ac controls.jpgac controls in dash.jpg
    Still waiting on the upholstery shop to get me in. He's doing headliner,molded carpet, covered waterfall, door panels. Hopefully he calls this week.
    285/25-20 rear
  35. Likes FF33rod, RoadRacer, 33fromSD, narly1, HVACMAN liked this post
  36. #142
    Sep 2019
    Car is looking great.
    You mentioned you are 6'3", with you seat bracket set up how much distance is there between your head and the hardtop?
    I like the bracket setup you used and I have the same seats.
    I'm 6'2" and I'll be rnning my car on the track so I want to make sure I've got enough clearance.
    Andy
  37. #143
    Apr 2019
    Dunlap Tenn
    I haven't actually measured the space above my head, but I'm pretty sure its at least enough for a full face helmet. I will check tomorrow and get the exact number.
    285/25-20 rear
  38. #144
    Everyone is different ratios, torso, etc, but at 6' tall there seems acres of space above my helmet - a good fists-worth 3-4"?
  39. #145
    Sep 2019
    James,
    Thanks for the feedback. I just checked out your build thread and see you used the Breeze brackets too. I hadn't thought about sub belt yet. I like what you did.
    Andy
  40. #146
    James,
    Andy
    I just measured so I’m not “remembering”.. I have 5.5” above bare head, 2.5” above helmet. Yes I have breeze bracket
  41. #147
    Apr 2019
    Dunlap Tenn
    James,
    Even with the seat all the ways forward, you are correct at least 4-5 inches.with red grill.jpg The grill painted to match the car.
    285/25-20 rear
  42. Likes RoadRacer liked this post
  43. #148
    Sep 2019
    Guys,
    Thanks for the feedback on the head/helmut clearance. I'll be ordering the breeze brackets too.
    Andy
  44. #149
    Apr 2019
    Dunlap Tenn
    getting the car ready for the upholstery shop to do their thing. molded carpet,headliner,waterfall covered,door panels...took it for a ride. No top,no windshield, pure fun....dirty car.jpggetting a bath.jpggetting ready for top.jpg
    285/25-20 rear
  45. Likes narly1, 33fromSD liked this post
  46. #150
    Apr 2019
    Dunlap Tenn
    Hey you guys, I just remembered something I wanted to run by you. After my drive yesterday I noticed my drivers side rear brake rotor was shiny about 1/3 the way from outside in. The others were shiny from braking as should be. It was easy to spot because there was a bit of surface rust on the rotors. Any thoughts on what that is all about. Tomorrow I'm going to pull the wheel and inspect...maybe e brake, dirt in the pad...etc
    285/25-20 rear
  47. #151
    Jun 2020
    SoDak
    Did you go through the bedding of the brake pad process yet? Pads may not fully seated yet. You may have also had an air pocket in the driver's side caliper. May not hurt to bleed the rears again.
    The only other thing I can think of is did you thoroughly clean the rotors with brake cleaner before installing them to remove the oil / protection suppliers put on rotors. I found this needs to be done a couple times per rotor to get everything really clean.
    Jim
  48. Thanks Blade thanked for this post
    Likes Blade liked this post
  49. #152
    Jun 2020
    SoDak
    Also look at the brake bias bar, if it's set too heavy on the fronts you may only be light scuffing the rotors in the rear.
    Jim
  50. Thanks Blade thanked for this post
  51. #153
    Apr 2019
    Dunlap Tenn
    Thanks Jim,
    I have not bedded these brakes. I haven't had the opportunity to do so. I will tomorrow. I will do a thorough inspection just prior to bedding. I knew if I asked you guys I'd get a comprehensive list to work from.
    285/25-20 rear
  52. #154
    Apr 2019
    Dunlap Tenn
    Do you guys know if the wiring schematic(and break down of color coding in the manual) for the tail lights is accurate?
    285/25-20 rear
  53. #155
    I don't remember any problems. The headlights caused some discussion I remember, but the tail lights were super straightforward.
  54. #156
    Jun 2020
    SoDak
    I cannot find it in my post, I thought I documented the wiring for the head light, but if you search for headlight wiring on the forum, a bunch of guys have documents the proper way to wire the headlights.
    A lot depends upon if you want to run day time running lights on the LED setup or use parking lights. Both are wired differently.
    Jim
  55. #157
    Village Mills, Texas
    The wiring for the tail lights is pretty straight forward, as RoadRacer said. The main thing to remember is DO NOT use the purple wire.
  56. #158
    Apr 2019
    Dunlap Tenn
    All the wiring issues emanating from me wiring the connections on the brake light switch wrong. I had to start fresh, everything works as it should. Now it seems I'm having a clutch issue. My painter and I took the car for a spin. No top, into the wind, I let him drive a little. Everything worked perfect. Yesterday Zane(painter) asked me to come by the shop and move the car to the other side of the yard, started great when right into first, but a minute later the clutch pedal felt tough to push in and seemed to want to stay down. Then no clutch, reservoir full,getting a bath.jpgout for a short shake down ride.jpgdirty car.jpg no apparent leaks on the floor where it was stored(I'm waiting for the top to be cut and buffed) any ideas are welcome. I'm going to pull the dash and check the pushrod and master. then get under and go for a bleed. Am I leaving anything out?
    285/25-20 rear
  57. #159
    If no fluid leaked then has to be the mechanical bits? So yes, pushrod and whatever is at the other end (Is it external with lever, or throwout bearing?)
    Tough to push and staying down doesn't sound like needs bleeding..
  58. #160
    Apr 2019
    Dunlap Tenn
    hyd throw out bearing. I am going to look for the rod maybe came out of the master cylinder, or something in that area.
    285/25-20 rear
