Them damm doors again
530FFA9A-B947-4254-B079-F2FA1E07BC74.jpg04BC01E4-0381-43DF-8C4D-DE6255665DC6.jpgF8B5DF9A-5F64-4508-B12F-ED0535764EE0.jpg
I am starting to fit the doors. I know there’s a ton of information and I think I’ve read most of it. Just as a point of reference. Can I assume that the body lines on the door align with the body lines on the body. So that must give me a point of reference for trimming the top and the bottom of the door. These doors have not been touched yet.
16+ FFR kits and counting!
Yes they should line up perfect with the body lines after that then worry about your gaps. it takes some tinkering and tweaking, twisting . Don’t be afraid to loosen the carriage bolts on the crash beam and the latch bolts all at once then twist and hold the door then retighten everything . Rob
FFR 35 p/u # 0016 Dart 347 TKO 600
So the drivers door is fitted!!!!! I am still waiting for the other shoe to fall. Here is how I have done it so far. I fitted the tee brackets on the body. Then I made up the 3/16” spacer for the door to sit on. Then I trimmed the top and bottom to get the belt lines to line up. Then I cut and sanded the sides and corners to fit the door into place.At this point in most places I have no gap. When I got to the point that the door just fit and the belt lines matched I taped the door in place and am moving on to the other door. All 4 corners of the door fit perfectly no twist whatsoever. So now when I cut the hinge openings and add the hardware inside should the door stay as perfect as it is now?
CBB26561-9A5C-4080-8AEA-0FA1E75759A3.jpg2A275149-7C00-49EF-8255-5EFBE4602ED9.jpgCC24A7A3-21C9-49D5-AEC4-07A6840F72BC.jpg
