Results 1 to 9 of 9
Thread: EFI Questions
    Jan 2020
    Western New York
    EFI Questions
    I am using a Holly Sniper EFI on my roadster, 302 with approximately 380 HP. I have 3 maybe 2 and a half questions:
    1- Can I use the 5/16" fuel line & 1/4" return line supplied by Factory 5 or do I need 3/8" fuel and return line? I think I saw someplace that 3/8" were suggested for the Sniper.
    2- I bought the in tank fuel pump, I assume I need a fuel filter, should it go in the engine compartment or can I put it close to the tank.
    3-If the 3/8" lines are needed should I buy a filter with a 3/8" inlet and outlet?....if needed at all.
    Thank you in advance for the help, this forum has already been a great help and it is appreciated.
    Doug S.
    Southport, NC
    Question 1 Fuel Line Size From Summit Racing
    Recommended Fuel Line Size (from the tank to the pump)
    Engine Output 350-450 hp
    Size (inches) 3/8 in
    Size(AN) -6 AN
    Question 2 Fuel Filter and Fuel Pump
    Make sure the pump is sized for the amount of Horse Power
    The fuel pump should have a 'sock' on it to filter out large debris
    A separate fuel filter mounted close to the rear tank pump filtering the fuel tank feed line. See builders manual.
    Question 3 Size of fittings for the fuel line
    I would get a filter that accepts -6AN fittings and use those throughout the fuel lines set up all the way to the Fuel Pressure Regulator and to the Sniper Throttle body.
    Return Line can be 3/8 or 5/16". I would, however, suggest you make all your lines 3/8".
    George
    Jan 2020
    Western New York
    George,
    Thanks for the definitive answers. Your help is appreciated.
    Doug S
    Jan 2020
    Western New York
    I forgot to mention I will be following your suggestion of 3/8" for both lines. Thank you!!!!
    Doug S.
    Southport, NC
    Quote Originally Posted by Doug er View Post
    Doug S.
    I built several items on my car realizing that sometime in the future I may add Horse Power or maybe the next owner may do so if I don't. So, it's always good to have a little wiggle room for future changes.
    George
    Senior Member jwhit's Avatar
    Oct 2019
    north carolina
    i am running a sniper on my 347 and i used 3/8 for supply and 5/16 on return with stock mustang fuel pump has not been issue but i am only pushing 370 hp so i could be issue for higher horse power motor
    Jan 2020
    Western New York
    Thank you Jwhit, I appreciate the input.
    bobl's Avatar
    Spicewood, Texas
    Make sure you get the fuel pump hangar for the 3/8 line also. I believe Breeze sells everything you need.
    Jan 2020
    Western New York
    Thanks for the reminder about the hangers and Breeze!!!
    Doug S.
