Likes Likes:  7
Results 1 to 40 of 40
Thread: MKIV Roadster for Sale
    Jun 2017
    1989 Fox Mustang GT donor
    8.8 rear end
    302ci engine - all new top end
    T5-Z spec
    Hydroboost with adjustment knob
    Power Steering
    1995 Cobra front brakes and rear Lincoln Mark brakes (all new rotors/pads)
    4 link rear suspension
    17" Halibrand Wheels - (4) new toyo tires
    Hydroboost brakes - works flawlessly
    Maximum Motorsports Adjustable clutch cable
    Kirky high back seats
    Cobra glove box from Alex custom roadsters with lock
    GPS gauges from Speedhut (over $1000 for all)
    S/C Cobra dash layout - CNC cad design mirrors original
    Trick flow Aluminum 11R heads 190cc (new)
    Scorpion roller rockers and Trickflow push rods and new Ford Racing roller lifters
    New water pump, etc.
    Electric fuel pump with Aeromotive regulator (6.5psi) adjustable to your desire - retained stainless steel return fuel line for future use
    Holley 650 carb with mechanical secondaries
    Edlebrock air gap intake manifold
    Trickflow stage 1 cam
    FFR radiator from FFR (new)
    Breeze radiator shroud
    Breeze air diverter
    Footwell lights
    Cobra sun visors
    Various Breeze parts as well.
    More pictures and more details available.
  2. Likes CaptB liked this post
    Dec 2017
    SW Fl
    Looking good, good luck with sale..
    Dec 2019
    Hello, where is this car located?
    Jun 2017
    Waukesha, WI
    Member GrooveM's Avatar
    Jul 2021
    Westby, WI
    Hi there. You mentioned that it was running in 2016 but you recommend a lower half engine rebuild. Is it not running now or is there an issue that needs to be addressed? I live on the west side of Wisconsin btw. Also, I assume there’s a windshield for it?
    Aug 2017
    Michigan
    Is the car titled yet?
    Jul 2021
    Westby, WI
    Is this project still available?
    Jul 2021
    Westby, WI
    Morning. I'm still watching this post but I would like more pics and answers to my questions from a few days ago. Thanks and have a great day!
  10. #9
    Jun 2017
    Yes, it is titled and running great. Registered as a 65 cobra. Has all the parts needed for completion. Paint will be done in about a month. Then I will be asking $41,000 or possibly more.
  11. #10
    Jun 2017
    https://youtu.be/0LtkXeUU4Fg
    Lots of time and $$$$ in this car. I am flexible on 35k right now, but after paint, I’ll be firm at 41k. The dash has over $2,000 in it alone. Original CAD design as a super comp cobra. Alex cobra glove box, custom hidden buttons for clock amd gas gauge. GPS speedo, reverse 200mph. T5z trans, heads were 2k. All wiring is done. Body was fit and gaps are good.
  12. Thanks NoBars thanked for this post
  13. #11
    Good luck! Hope she finds a worthy home.
  14. #12
    ATX
    Was the car ever registered?
  15. #13
    Jun 2017
    The roadster will be painted and finished in about a month. Deep Impact Blue Metallic with white stripes. Added a few more things, even though I promised I wouldnt spend more! When done, will be asking 41k-45k. Options include, glove box, manual choke installed with boss 302 cable, 1965 hazard switch and ignition switch and headlight bezel, reverse GPS 200mph speedo, air vents (cobra earls), hidden dimmer for gauges, two 12v cig lighters, russ thompson turn signals, real super comp dash layout by CAD design, hyd clutch and power steering. New ffr radiator amd breeze support kit and shroud. Hope its done soon!
  16. #14
    Jun 2017
    Any other ideas for the color? I hear red, green and black are also popular....
  17. #15
    Oct 2019
    Quote Originally Posted by miker351w View Post
    The time has come to sell my project that I took on last year. It was originally bought by a dear friend of mine in 2011 and was a running/driving car in 2016. Due to various reasons, he parted ways with it and I bought it. I have since revamped a large portion of the vehicle. I had it slated for paint a month ago, but the painter is now significantly delayed, so it is sitting at a shop. The good news is the body work prep is mostly done. I also fit the body multiple times so it came out nicely.
    Reasonable offers will be entertained. All receipts available from new. Spreadsheet was kept as well.
    T5-Z spec
    Power Steering
    17" Halibrand Wheels (need new tires)
    Hydroboost brakes
    Hydraulic Clutch
    Cobra front back brakes
    GPS gauges from speedhut (over $1000 for all)
    Cobra dash board like original
    Scorpion roller rockers and trickflow push rods and new Ford Racing roller lifters
    Electric fuel pump with aeromotive regulator (6.5psi)
    With all invested, I am looking to get $35,000 for it. A few things I would recommend would be a new short block or a rebuild on the lower half of the engine. Attachment 151503Attachment 151504Attachment 151505Attachment 151506Attachment 151507Once done, it will be a be very nice. Thank you,
    Please consider $27,000, I assume it comes also with the windshield and a clear title. I checking on engine availability and around here they are quite expensive, like 5K and more. Thank you.
  18. #16
    Oct 2019
    $28,000 if its still available. Let me know. Thanks
  19. #17
    Quote Originally Posted by FCABARLE View Post
    Just a hint. PM's would be a better place to negotiate.
  20. Likes miker351w liked this post
  21. #18
    2021 Dodge Challenger Torred Looks Spectacular On My Ride!
    .........................https://youtu.be/9WEe6-wdNtA
  22. Likes miker351w liked this post
  23. #19
    Nov 2021
    Pittsburgh, PA
    PM sent, interested.
  24. #20
    Jun 2017
    Jun 2017
    Almost ready to pick her up! Winter will slow things down until spring though. Glad I went along and finished it up.
  26. #22
    Senior Member Lickity-Split's Avatar
    Oct 2020
    S. E. Michigan
    My roadster is also red. But, I think I like the smooth curvy lines of your hood without the scoop better. Nice ride!
    "You never know how strong you are, until being strong is the only choice you have."
    FFR #7430 - MK4 Roadster - 302 w/ T5 Five speed - 17" FFR wheels.
  27. #23
    Jun 2017
  28. Likes GoDadGo liked this post
  29. #24
    Mike,
    Very Nice Job & Hope You've Decided To Keep It!
    Apr 2015
    Hello! Is this car still for sale?
  31. Likes miker351w liked this post
  32. #26
    Jun 2017
    The car is finished. Thinking of moving on in the spring. It needs a few minor things. Only has 80 miles on it. Paint is dusty in video, not one scratch. White stripes are inlaid into the paint. The whole car was painted Deep impact blue metallic (Ford color offered in 2014), with flake, same flake ratio in white (Color is Shelby GT500 white), then cleared with 3 coats. Painted by Mukwonago Custom Color Creations. Have the paint codes available. The whole car was
    sanded multiple times, then cleared, painted the stripes and sprayed 3 clear coats over everything. The roll bars were painted gloss black with flakes. After this, it was sanded again. The paint has not been washed since and in storage. Brand new Toyo tires, 315 in the rear.
    Has extra parts with it (extra door, over-riders painted black). Has a new 650 double pumper on it. Electric choke, with a manual choke installed (disconnected). GPS gauges. 2 12v chargers under dash. All gauges from Speedhut. 65 ford hazard switch. footwell lighting. Cobra earl feet coolers. Insulated well. Trunk carpet.
    PM serious inquires only. $48,500/best offer. Would like to have a buyer lined up for Spring.
    *Side note. This has the Kirky seat buckets. Ideally the driver would be 5'10+. I am 6'0 and it is perfect. 6' 1-3" would still be a good fit too.
    https://youtu.be/75OstRIuhaQ
  33. #27
    Jun 2017
  34. #28
    Namrups's Avatar
    Sep 2021
    Mechanicville, NY
    Cant view any of the attachments
    Scott Pregont
    My Albums
  35. #29
    Good Luck!
  36. #30
    Jun 2017
  37. Likes svassh liked this post
  38. #31
    Jun 2017
    ***updated****
    8.8 rear end
    -While it was out - New oil pan gasket, new timing cover, new water pump, new timing chain (comp cams)
    T5-Z spec
    Power Steering
    Breeze air diverter
    Footwell lights
    Cobra sun visors
    66 miles on the odometer. updated price.
    $48,500/best offer.
  39. #32
    Sep 2022
    Did you ever sell it? I'm in Racine
  40. Likes miker351w liked this post
  41. #33
    Nov 2021
    Pittsburgh, PA
    PM sent, I'm back in the market for a Cobra and it looks like this may still be available.
  42. #34
    Jun 2017
    Yes, still available. 75 total miles on the odometer. Updated video here. https://youtube.com/shorts/4hVQdNXEwgw?feature=share
  43. #35
    Jun 2017
    $55,000 or best offer
  44. #36
    Senior Member gbranham's Avatar
    Jul 2021
    Tonganoxie, KS
    Price went up $6500 since Feb 2023? Other than the few top end bits that were freshened up, did anything else change?
    Build Thread Here Partners: Levy Racing, Summit Racing, LMR, Breeze, Forte's Parts, Speedhut, Amazon
    MkIV Complete Kit Ordered 4/18/23, Delivered 7/11/23, Boss 427W, Edelbrock Pro Flo 4, TKX (.68 5th), IRS, Wilwood Brakes, 18" Halibrands, Toyo R888R Tires, Custom Speedhut Gauges
  45. #37
    Dublin, OH
    Quote Originally Posted by gbranham View Post
    he has stored it for the past year after all...
  46. #38
    Jun 2017
    I had 2 serious offers, but thought I would end up driving it more, but ended up letting it sit for most of the season because I have two kids/busy. Some changes made. Motivated seller
  47. #39
    Jun 2017
    $53,000 (reduced price)
  48. #40
    Jun 2017
    **sold**
