Results 1 to 4 of 4
Thread: Spindle Nuts
    Jan 2021
    Spindle Nuts
    Hello to the group. Spindles came in finally and when double-checking the manual it says to torque to 220 foot pounds. Seems like a lot of pressure on the bearings. Can anyone confirm for me?
    Quote Originally Posted by only1moreracecaripromiss View Post
    That's what it is. I seem to recall more like 250. But whatever the manual says. It doesn't put undo pressure on the bearings. You'll find they spin freely. You're probably thinking of the old school type bearings where you repack and tighten to where they're tight and smooth and pin the nut with a cotter key. These are permanently lubricated bearings made differently.
    Jul 2020
    Pretty sure there’s a spacer in the hub that butts against the inner races of the inside/outside bearing. We actually used non locking nuts as we were removing the hub a lot. The locking nuts have a crimped collar that starts stripping the threads on the stub axle.
    Senior Member lewma's Avatar
    Jan 2018
    San Marcos, CA
    You got nuts already ? My spindles came in last week but still no sign of hub nuts...
