Thanks Thanks:  3
Likes Likes:  36
Page 1 of 4 123 ... LastLast
Results 1 to 40 of 124
Thread: Budget LS Factory Five Roadster
    May 2013
    Seattle, WA
    May 2013
    Seattle, WA
    Options I Chose
    Senior Member JB in NOVA's Avatar
    Apr 2020
    Virginia
    Great videos! I'm looking forward to following along with your adventure. Welcome aboard!
    MKIV Complete Kit #9822 l BluePrint 347 EFI l TKO600 l Power Steering l Heater/Defrost l Build Thread
    May 2013
    Seattle, WA
    May 2013
    Seattle, WA
    May 2013
    Seattle, WA
  7. Likes GoDadGo liked this post
    May 2013
    Seattle, WA
  9. Likes GoDadGo liked this post
  10. #8
    May 2013
    Seattle, WA
  11. Likes GoDadGo liked this post
  12. #9
    May 2013
    Seattle, WA
  13. Likes GoDadGo liked this post
  14. #10
    May 2013
    Seattle, WA
  15. Likes GoDadGo liked this post
  16. #11
    Placitas, NM
    Great choice on the LS engine. Pretty sure you probably know you’ll need to get the theft features removed from the ECU.
    Have a great time with your build.
  17. #12
    May 2013
    Seattle, WA
  18. Likes GoDadGo liked this post
  19. #13
    May 2013
    Seattle, WA
    Supposedly already done from the seller.
  20. #14
    May 2013
    Seattle, WA
  21. Likes GoDadGo liked this post
  22. #15
    Remember to route your rear wiring harness before you permanently install your trunk floor pans.
    Also, pre-drill your roll bar(s) prior to fitting the rear cockpit aluminum because it will really make that task a lot easier too.
    Good Luck & Happy Riveting & Wrenching!
  23. #16
    May 2013
    Seattle, WA
  24. Likes Dieter123, GoDadGo liked this post
  25. #17
    May 2013
    Seattle, WA
    Wow, thanks.
  26. #18
    May 2013
    Seattle, WA
  27. Likes Dieter123, GoDadGo liked this post
  28. #19
    Make sure that you DON'T install the driver's side outside foot-box panels until after you've done some shakedown Go-Kart runs.
    Leaving those off will make life a lot easier in the event that you find yourself needing to adjust things as your build progresses.
    Good Luck & Happy Wrenching!
    PS:..Your Son Is Super Cute Handy Helper & Will Be A Major Motorhead Forever!
  29. #20
    May 2013
    Seattle, WA
  30. #21
    May 2013
    Seattle, WA
  31. #22
    May 2013
    Seattle, WA
  32. #23
    May 2013
    Seattle, WA
  33. Likes WIS89, john42 liked this post
  34. #24
    "The I.E." SoCal
    Mathew, If you'd like to allow your videos to play directly here on the forum rather than opening a new window, reply and click on the "insert video" icon and then load your link.
    Abracadabra.
    __________________________
  35. Thanks WIS89 thanked for this post
  36. #25
    May 2013
    Seattle, WA
    May 2013
    Seattle, WA
    Fantastic, thanks!
  38. #27
    May 2013
    Seattle, WA
    May 2013
    Seattle, WA
    Dublin, OH
    Quote Originally Posted by mcannon12 View Post
    are you going to remove that rivet for your headlights before covering your dash or just cover over it and let the dash material get sandwiched down by the outer bezel?
  41. Likes CaptB liked this post
  42. #30
    May 2013
    Seattle, WA
    May 2013
    Seattle, WA
    Gonna leave the river. It secures that headlight switch better than the nut. Prevents the switch from rotating.
  44. #32
    May 2013
    Seattle, WA
    Dec 2021
    Thanks for posting this - really helped me plan out the EFI in tank pump/regulator and filter for my LS376. I reviewed a few articles as well and feel this is a simple and cost effective, yet reliable, set-up.
  46. #34
    May 2013
    Seattle, WA
  47. Likes CaptB, john42 liked this post
  48. #35
    May 2013
    Seattle, WA
    May 2013
    Seattle, WA
    May 2013
    Seattle, WA
    May 2013
    Seattle, WA
  52. Likes Qballz liked this post
  53. #39
    May 2013
    Seattle, WA
    May 2013
    Seattle, WA
