Thread: Ron Francis wiring and radiator sender unit
    Dec 2020
    Layton Utah
    Silly question, but the sending unit for the Ron Francis radiator switch, I'm guessing I get one that fits my radiator that turns on at 185 or 160, and that's where the fan switch wire connects to turn on the radiator fan.
    Any preferences on a temperature?
    "The I.E." SoCal
    There should be one with the loose wiring component sent with your kit.
    __________________________
    Quote Originally Posted by DAVID_T View Post
    I assume you are running a carburetor and not fuel injection? For EFI, don't install the thermal switch that came with the kit, but let the EFI control the fan.
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    185-190 for a carb engine. 195 for efi.
    Dec 2020
    Layton Utah
    It's a carb. The one that came with the kit doesn't fit my radiator. I need to find one.
    Thank you!
    "The I.E." SoCal
    Thank you!
    That's because it goes in the coolant tract of the intake manifold.
    Senior Member nucjd19's Avatar
    Jul 2020
    Birmingham, AL
    Quote Originally Posted by frankeeski View Post
    Agree. pulled a coolant plug on the manifold and screwed it in with some permatex on the threads.
    FFR MK4 Roadster (9945) complete kit, delivered 12/4/2020, First start and go kart 5/7/2021. Legal 8/14/2021, Paint finished 7/18/2022 (Viking Blue). 347BPE CI, TKO600, Moser 8.8 3link 3.55, Halibrand 17x9 17x10.5, power steering. Carbon Fiber Dash. Carbon Fiber trans tunnel, adjustable Kirkey Lowback Vintage seats, Vintage gauges, RT drop trunk mod, FFmetal drop battery mod and trans tunnel, Forte front sway bar. Forte mechanical throttle linkage, RT gas pedal. www.covespringsfarm.com
