Hose and wiring routing
Hey Guys
I am starting to run the wiring on my truck. I wonder if some of you guys could post pictures of how you ran the wiring in the engine compartment as well as the the hose runs. I am running a 383 stroker and a Fietec EFI. Full fender and sides.
There's going to be a lot of variation in routing, holes through the firewall, etc. based on engine, trans, and personal preference. I show where I did mine in my build thread (link below) but it's an LS3, auto trans, and I made quite a few changes to the RF harness. So don't know how useful it would be for you. The manual does a decent job of explaining and showing where Factory Five did theirs. I found that helpful although didn't follow it exactly. Best I would recommend is mock up all the major components (engine, trans, etc.) and determine best locations and routing for your build and preference. One big decision is where to route the main power feed and rear harness. Some take them through the driveshaft tunnel (I did) while others route them under the chassis.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
Suggest you temp wire everything to get working, then figure how to make it neat; lots of wire can be eliminated, smaller gauge for digital bulbs etc. Then start at the corners and bring the wires to the dash. Really neat wiring has no pictures because it you can't see it
