Results 1 to 3 of 3
Thread: Wilwood Rotor Hat Bolts, p/n 23-8008
    Senior Member 32J's Avatar
    Dec 2018
    Sherwood Park, AB
    My dang torque wrench got stuck and I ended up shearing a hat to rotor bolt, Wilwood P/N 230-8008, 1/4-20x0.75 LG.
    I only need the one! A full 12-piece kit from Wilwood will cost me nearly CAD$100.
    32J
    I can’t help you with one bolt but you do realize that the torque spec is inch pounds, not foot pounds—-right?
    Dec 2018
    Sherwood Park, AB
    Yes, had it set to 155 in-lb. I did the rear brakes just fine 4 weeks ago. My torque wrench jammed some how and didn't click. My fault for not paying attention. Worked fine on all the other bolts.
