pyramidbuilders
Where do I get the Mk4?
You say your Moser rear end. I was under the impression that you did not offer a dif and I had to find my own. I definitely want disc brakes and a strong rear end as I will be supplying over 400 ft. lbs. torque. Can you be a little more specific on what I should look for?
Also, please answer this question. Is anyone using independent rear suspension?
The Mk4 is the roadster replica kit.
Factory Five does sell a rear end through Moser. I believe it is only available if you want to run the upgraded 3-link suspension, but will work in the 33 if you're planning on doing that.
Factory Five does not have an IRS option for the 33 (well right now anyway), but there are a couple of builders who have fabricated their own.
