Thanks Thanks:  4
Results 1 to 9 of 9
Thread: Electrical Connector Part Identification
    May 2021
    York, UK
    Hi
    I am going through an inventory check of my kit that has recently arrived and just wanted verification on an electrical part.
    This is for a right hand drive 818. Can someone please confirm whether the item in the photo is "81003 H7 Headlight Connector"
    Oct 2019
    Erin, Ontario CANADA
    Those are weatherpack connectors. An H7 bulb has 2 flat connector tabs on its base.
  3. Thanks DJWalker thanked for this post
    Senior Member fletch's Avatar
    Dec 2018
    Just outside ABQ, NM
    BTW, those are nice connectors. Is FFR shipping weatherpaks with new kits?
    May 2021
    York, UK
    Thanks @narly1
    Could they be
    81001 Shutter connector
    In the manual, there is a picture of what I thought was the shutter connector that matches another part I have - a pair of connectors already attached to wires and so I have checked that item off as 81001, but perhaps I am wrong.
    There is no mention of weatherpack in the packing list and I can’t really see any other option that these things might be.
    Oct 2019
    Sorry I can't help you there, but I will say that Weatherpack connectors would be a great connector choice for that type of application.
    Earl
    Apr 2020
    My left hand drive kit from 3 years ago came with:
    80979 US headlight components which contained:
    81000 H9 headlight connector
    Looks like your right hand drive comes with 81003, a connector for a slightly lower power H7 bulb which requires a different connector. So, instead of an H9 connector with short wires attached, you got an H7 connector and will have to add the wires. Enjoy your build!
    RPG
  8. Thanks DJWalker thanked for this post
  9. #7
    Dec 2018
    The connectors in the baggie look a lot like the connectors I have for the projector headlamp high beam shutter. Mine came as pigtails, but I bet it's the same connector. Find one of the pretty yellow Hella boxes and see if the connector in the bag matches one on a headlamp shutter. Good luck.
  10. Thanks DJWalker thanked for this post
  11. #8
    Apr 2020
    It is labeled a Delphi connector and looks a lot like a GM Delphi / Packard - 2 Way Metripack 280 Connector Plug for 9006 / H7 / HB4 Headlight Bulb shown here:
    https://www.bmotorsports.com/shop/pr...UaAuQ4EALw_wcB
    The best way to tell, of course, is with a trial fit. Good luck with your build.
    RPG
  12. Thanks DJWalker thanked for this post
  13. #9
    May 2021
    York, UK
    Thanks everybody, looks like the answer is “yes”. I’ll check it off as OK. Unfortunately, my headlights haven’t arrived so I can’t use them as a check.
