Thanks Thanks:  3
Likes Likes:  50
Results 1 to 40 of 62
Thread: DLJ's build thread
    Nov 2021
    Chicagoland
    DLJ's build thread
    Greetings,
    I bought grabera7's just started 818r, complete with donor parts, so now I guess I'm in the game...
    The work he completed- mostly front and rear hub carriers, suspension arms and steering- are first rate. Since he's already stripped the donor, a 2006 STI, I get to do the fun part...
    A recently retired engineer, and always car guy, I'm enjoying it already. Though figuring out what has to be modified, changed, or adapted since its an STI gets me head scratching occasionally.
    I'm located in the western suburbs of Chicago. I really hope to connect with other 818 builders located within an hour or two; what's the best venue for that? The Regional Discussion forums seem pretty sparse.
  2. Likes David Hodgkins, jbs72697 liked this post
    That's a sweet kit!
    Best of luck with the build. I upgraded your account to full rights so you can post pics, update your profile, etc.
    Welcome to the forum!
    Aug 2020
    New Paltz, NY
    Welcome to the club!
    May 2020
    Welcome to the madness! I started my kit recently so I am still early on in the process, but also am building an 818R in "Brandon's 818R Build." Lots of learning and head scratching.
    Sgt.Gator's Avatar
    Bend, Oregon
    Welcome to the forum. The first head scratcher is to figure out if you need to worry about the "broomstick test." If you are tall you won't pass the test at many tracks, and certainly won't in the organized racing bodies. If you won't pass now is the time to make the frame mods so you can pass. Which means either raising the rear roll bar or fabricating a full HALO cage. If you are shorter be glad!
    Owner: Colonel Red Racing
    818R ICSCC SPM
    Nov 2021
    Chicagoland
    I didn't say but I don't plan on actual racing. I do track days- last year about 8; probably 12+ next year. Currently using a Porsche Cayman, Hopefully 2023 season will be with the 818. Still, the broom stick test is relevant. In August, saw a car doing a slow roll over at VIR. The driver- and his instructor- tried pretty hard to make it happen but, "there but for the grace of God go I." So need to be ready...
    My plan is to visit folks, if possible, and check the forum and see what seats are popular. But yeah, I want to get seats fitted in to check this, and before setting up the shifter, steering column, etc.
    Senior Member Rob T's Avatar
    Woodruff, SC
    Welcome aboard. It's nice to have another R that will be tracked. I used to live in the West Suburbs of Chicago as one of my 10 locations during my career But now live in SC.
    Nov 2021
    Chicagoland
    First progress update
    This is my first build report, so be gentle...
    As noted, I bought an already started kit. The previous builder had- very expertly- completed the 4 corners, the front firewall, and Wilwood pedal assembly.
    It took a while to get a few supporting items completed before dropping in the "lump." Figuring things out like the STI axles, getting the frame modified for the 6spd, getting some aluminum and cut for a firewall. Anyway, got it in.
    While waiting for stuff, got a few other things done; rebuilt the brake calipers, a few engine items- timing belt, cyl 4 cooling kit, and started routing brake lines. Since I wanted to play with brake lines, I needed to locate the remote cylinders, which meant locating the windshield bases, which meant cutting both R and S bases for the R frame members. The best thing about that profanity fueled effort was the smell of cut fiberglass; forgot how much I like it...
    Up next: I'm not really doing much with the engine before getting it all together and determining where I want to go with it. BUT, a friend just had a nice little fire in his daily STI, when that rubber oil return hose behind the turbo burst and, yeah, you can imagine. So gonna replace that with a higher temp version.
  10. Likes blomb11, biknman liked this post
  11. #9
    May 2020
    Nice work and progress!
    You are bringing up something I have not looked at yet running the S windshield on an R. Looks like I need to look into this and how you would fill the master cylinder with the S windshield surround installed. I am thinking you would have to cut in some access holes to allow for a funnel or something. Do you have a side view picture of the master cylinders under the windshield surround? I am going to start routing my brake lines are well in the next couple of weeks.
  12. #10
    Nov 2021
    Chicagoland
    My kit has the Wilwood pedal assembly which uses separate master cylinders and remote reservoirs. You can see the 2 bright chrome cans in the 3rd pic. I don't necessarily love these particular reservoirs, but in any case, remote units can be mounted away from the master cyl. Otherwise, yeah, I think you'll need to cut some access.
  13. #11
    May 2020
    I am looking at getting a Tilton tri master cylinder rather than using the Wilwood chrome ones. I missed them in your pic, but it is nice to see what the windshield surround looks like on the R chassis. Getting thinking about how things will fit down the line.
  14. Likes grabera7 liked this post
  15. #12
    Nov 2021
    Chicagoland
    Fuel hose progress
    Got the first draft of the fuel hose system installed. I have a bunch of things still to figure out. I know I need a pressure regulator, but don't yet comprehend what exactly; a bypass type?, compensated? Where and how to connect? Do I need an aftermarket pump regulator?
    I'll be digging into the Fuel System thread...
    I enjoy messing with the AN hoses, gotta say. Takes me back to helicopter mechanic days.
  16. Likes blomb11, biknman liked this post
  17. #13
    Nov 2021
    Chicagoland
    Update: It starts!
    Its been quite a while since I posted, but got a lot done before a summer break, and now I'm back at it...
    Pretty happy with the wiring. I probably left more than is needed but wanted to get it started before cutting more. And it cranks!
    I decided as others have to leave the M/B fuse box forward as it many serves the lights, rad fan, etc. It meant adding a couple of hefty wires back to the alternator, but it allows spreading out the fuse boxes.
    Also happy with the e-brake solution and the position relative to the ZDB shifter and cables.
    with the stock firewall in place
    Should be go-karting in the next day or so.
    A little concerned about adjusting the ZDM shifter/cables. For now its feels pretty crunchy
  18. Likes Bob_n_Cincy, mikeb75, Kurk818 liked this post
  19. #14
    Nov 2021
    Chicagoland
    Cockpit work
    I've been pretty pleased with the wiring layout I ended up with. I have the brown F/B fuse box and one relay bar inside and the black M/B fuse/relay box in the front area closer to what its connected to; headlights, fans, horn, etc.
    I reworked the console aluminum to fit the ZBD shifter layout and allow for some extra gauges. I made a little door to access the F/B.
    I was stoked to find this gauge; intake air temp measured at 2 places; I put before and after the IC. Should useful to check airflow tweaks. Is anybody else using this?
    I modified the passerger side "interior" firewall since I have a Boyd fuel tank. It allows mounting the passenger seat back further.
    I made a version of the bicycle lever reverse lockout. Probably will tweak this as it's over complicated.
    Hoping to kind of wrap up the cockpit soon and start trying to fit body panels.
  20. Likes blomb11 liked this post
  21. #15
    Nov 2021
    Chicagoland
    Positioning the seats and harness mounts before final cockpit sheet metal install. I lowered the driver's seat as much as possible and still have to scrunch a little to pass the broom stick test.
    Trying to figure out the shoulder harness mounts. As others have noted, the seat belt bar in the R is higher than the harness manufacturers recommend. The belts should go straight back to slightly down, not up.
    Didn't know this would be an issue when looking at seats, but the shoulder belt opening might interfere a little. Nothing for it now.
    Belt going up to the R bar
    Belt going to ?
    I'm considering a bolt in bar in the over the engine. Don't want to weld it in and permanently hurt engine access. Needs to be stout though; might have to find a calculator and commit an act of Engineering!
    Also needs to fit in and around the engine cover and block off plates; ugh
    Am I over thinking it? Maybe okay around town, but I'm setting up for track day work
  22. #16
    Fenton MI
    I think the belts in the engine bay will lead to premature failure of the webbing.
    Factory Five 818c #456
  23. #17
    Nov 2021
    Chicagoland
    Quote Originally Posted by Shawn818c View Post
    I agree in general. I was thinking of the area shown in red, above the close off aluminum, or somehow shielded.
  24. #18
    Syracuse, NY
    I also needed the shoulder belt mounting position to be lower. It's a good idea to keep them out of the engine bay. I welded the shoulder eyelets to the lower section of the 1.5" main cross bar that the roll hoop ties into. I also added some thick steel plates for added strength since the square tube is only 0.095" thick.
    MK3.1 Roadster completed 2011
  25. Likes driveslikejehu liked this post
  26. #19
    Nov 2021
    Chicagoland
    Yeah, H.R. that's a solid solution. The height I need would put my attachment pieces on top of that square tube, which would make it easier. I will have little room to implement it, as the seat is far back, but may work. I thought I saw something about the shoulder belt anchorage not being too close to the seat/shoulder but I don’t find it mentioned in my Sabelt instructions.
    Welded options are a pain as I have to take the whole rig to my guy. Not fun in a Chicago winter. ( I need to learn to weld…)
  27. #20
    Nov 2021
    Chicagoland
    Going slow when the temps are low...
    When its warmer (30+) I'll heat up the garage and work a while. When its colder I'm in the basement cutting out body vents.
    Got the FFR mono wiper installed. Not adjusted, gonna need a windshield for that. At least got the electrical handled.
    Also working on trimming out the shifter and e-brake areas a little. Needs a bit more work, but getting there. I like the idea of covering this aluminum with wrap material. Hides a few hammer marks.
    Still figuring out the shoulder harness anchoring. Thinking of a bolt-in bar across the whole width behind the rollbar legs, sitting on the square tubes back there. Puts it about the right height. The HANS device actually raises where the belts head thru the seat and so helps the angle a little.
    I forgot to mention; I made a little boot for the ZBD shifter from a steering rack bellows. Is there a better solution?
  28. Likes jbs72697, blomb11, Bob_n_Cincy liked this post
  29. #21
    Nov 2021
    Chicagoland
    Mono Wiper install
    I installed the wiper motor a few weeks ago; easy, good instructions, all parts as expected.
    Finally laid the windshield in place temporarily to check arm and hood clearance. Using the provided hood support it fits well. I will trim the return flanges on the hood, but will trim in this area as well.
    3 tweeks to the wiper arm. The little button screw in area A hit the arm, I just reversed its orientation.
    At B, I bent it down a bit as recomended in the instructions
    At C, I bent it the other way to ensure the base come close to the glass, and under the hood.
  30. Likes jbs72697 liked this post
  31. #22
    Nov 2021
    Chicagoland
    Starting the body fitment
    As others have noted, fitting the fenders and hood is quite a 3-d puzzle. After a few trys, I backed off and measured everything (nearly).
    I found the hood to be even and square. The significant thing I found was the left fender was between 1/2" and 5/8" longer. I measure along the path shown in green and point to point
    So a nice looking fit in that area is future John's problem...
    I was pretty happy with cutting down the hood flanges.
    I tried a few tools; a body saw, an oscillating tool, dremel, then ended up using a hack saw blade in a pull to cut configuration. Used the oscillating tool for a few plunge cuts along the path, then the hacksaw. A little slower, but lots of control and not a ton of dust. See the little bit I cut off in the top of the tool pic
    The rear is coming along as well. I found one fender was slightly over 1/8" wider and the opposite flange was wider. After measurring to a center, I got them positioned within 1/16" at fender to shock tower, and a good fender to eng cover gap.
  32. Likes blomb11 liked this post
  33. #23
    Nov 2021
    Chicagoland
    Cutting the hood and rear cover flanges
    A friend who builds boats and does a lot of fiberglass work, recommended an oscillating tool for cutting the composite body panels. There may be a less clunky name for these things but that's what I see everywhere.
    They work well with the right blade; goes thru the panels with less violence than a body saw and way less dust than just sanding them down. I’m only getting started with these, so my first cuts on the hood I used the oscillating tool to plunge in a few places along the cut line.
    Then I cut the rest of the way manually with a hacksaw blade
    goes pretty fast
  34. Likes blomb11 liked this post
  35. #24
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    The helmet is a hoot. BUT the shifter really looks great - guts all visible and at the same time has a simple elegance in showing them. Boot rigged up is my kind of thing - repurposed instead of landfill - love it.
  36. Likes driveslikejehu liked this post
  37. #25
    Nov 2021
    Chicagoland
    Quote Originally Posted by aquillen View Post
    Thanks! My daughter does my helmets. She's a graphic artist and uses a technique called gesture drawing that I really like. It’s a little scary to give her a white helmet and see what I get back.
  38. #26
    Nov 2021
    Chicagoland
    Headlight mounting
    Big shout out to Blwalker105 for his headlight mounting method; at least that's where I saw it first. It worked well. I used his strings and weights concept to try to keep the screws parallel. This is IMPORTANT for fitting the buckets up.
    I didn't read his write-up thoroughly so had to add heat later to make the bucket fit better. Aluminum foil and an old shirt make a pretty good insulating blanket, lol.
    Also, made some doo-dads to make the nut fit easier.
  39. #27
    Nov 2021
    Chicagoland
    Dash modifications for R
    Pictures of the dash cut outs for R frame.
    another R dash; sorry, I fogot whose it is...
  40. Thanks blomb11 thanked for this post
  41. #28
    May 2020
    Thanks for sharing this will help me a lot. Pretty standard for the R to require some cutting and mods
    I just found that other picture from Mitch Wright and his R dash. These help to provide context where the manual falls short.
  42. Likes driveslikejehu liked this post
  43. #29
    Nov 2021
    Chicagoland
    DTC codes and warning lights
    I used RomRaider and the Tactrix cable to clear the DTC codes. Thanks and props to mcamera for the how-to. I ain’t gonna lie, it’s a pucker up moment when you hit return to upload your modified code to the ECU.
    Then I realized the other dash lights weren’t related to the ECU; ABS, Airbag, Rear Diff, parking brake/level lights. Gathering info from various other posts, here’s what I ended up doing. This is for my 2006 STI based car. Based on what I've read its applicable to other post 2004 cars; not 100% sure though.
    A couple of notes: I’m using the nomenclature from the manual referring to the 3 green connectors to the gage clustering; A=i12, B=i10, C=i11. Also, power to the dash; the RW wire going to C7 on the cluster is powered when switch is On. BW wire going to B1 is powered when engine is running.
    ABS light: LgY wire from B3; shorted to ground. Light stays out.
    Rear Diff light: YR wire from B4; shorted to ground. Light goes out when engine is running.
    Airbag light: GR wire from B18; jumpered to RW wire for switched power. Light stays out
    Brake light: Sb wire from A2; shorted to ground, light stays out
    I fretted a while about the DCCD text thinking it was a warning light. Then I realized its just text for the DCCD control area of the dash.
    From this
    To this.
    Now for some Four Roses…
  44. Likes jbs72697, Bob_n_Cincy liked this post
  45. #30
    Nov 2021
    Chicagoland
    Brake proportioning valve; April Fools!
    So I when I did my beautiful brake line work 14 months ago, I put the proportioning valve on the rear line. I guess I relied on the Wilwood instructions or old experience. Now I realized the manual as well as forum discussion indicate it should be on the front. I get it, potentially too much braking on the front with the weight bias change.
    Feel free to tell me I’m wrong, before I redo it, lol.
  46. #31
    Nov 2021
    Chicagoland
    Front end air flow work
    Like some other folks, I don’t like the idea of the air coming out of the radiator just being uncontrolled in the under-dash area. (tho this is the case in most road cars- air exiting the rad just finds its way under the engine and car).
    So, I added an additional aluminum wall and fab’d ducts to extract more air. These increase the exit area by close to 50% over the hood vents. Can go more if needed.
    Had fun with my first epoxy fiberglass effort
    Installed these in the blocking panel. They vent to the wheel well, which has openings to the extraction area between door and fender.
    I'm concerned that the one small opening in the front bumper feeds enough air to the radiator. I posted about it in the general discussion thread.
  47. #32
    Dec 2019
    Quote Originally Posted by driveslikejehu View Post
    A front engine car weight shifts a lot more than a mid car. They come with much bigger brakes on the front. The FFR Wilwood setup, if I understand it correctly, is the same - larger brakes on the front than the rear and dial the front brakes back. The 818 has about 65% weight in the rear, at least mine does, and being so low isn't going to dive much under braking. I went with equal size (large) brakes front and rear and put the valve in the rear line. I haven't adjusted it yet, but so far it seems OK.
    Ed
  48. #33
    Nov 2021
    Chicagoland
    Engine Cover first steps
    The vestiges of curved fiberglass on the R engine cover always bugged me
    So I cut them out, leaving enough of the panel to weaken and bend into shape
    When doing this on the humps area, I filled in the unneeded rollbar hole and extended down to meet the aluminum with some cut-off bits
    Will have to fill and finish before paint prep, but I feel better about it, lol
  49. Likes blomb11, Hobby Racer liked this post
  50. #34
    Nov 2021
    Chicagoland
    Replacement windshield
    When loading the windshield glass and frame to take for installation, I found I had cracked the glass somewhere along the way. FFR has them for $250 which isn’t bad, but shipping is $280. I was able to get a 2002 MR2 windshield and installation locally for $300. I’ll show the number in case it might help anyone.
  51. #35
    May 2020
    Nice great deal you found! Car is starting to come together for your first track day too.
  52. Likes driveslikejehu liked this post
  53. #36
    Nov 2021
    Chicagoland
    Headlights
    I attached the headlight “glass” with .045" VHB tape. There are few bubbles in the joint but- kit car.
    As others has done, I epoxied 8-23 screws in the fenders to allow removing the headlight buckets. I used adhesive backed 3/16” EPDM foam to form the seal.
    May seal around the glass with black silicone, but generally okay with the result.
  54. #37
    Nov 2021
    Chicagoland
    All covers on
    I needed a few shots to use in the registration process. Couldn't stop taking pics...
    Don't mind that some bits are held on by tape..
  55. Likes Rob T, blomb11 liked this post
  56. #38
    Syracuse, NY
    It's a great feeling when you see it all together for the first time. Nice job.
  57. Likes driveslikejehu liked this post
  58. #39
    Nov 2021
    Chicagoland
    Quote Originally Posted by Hobby Racer View Post
    Thanks! It's sort of a team effort with you folks on the forum that inspire and inform.
    The pictures somehow don't do it justice; its seems lower and leaner in person.
  59. #40
    Nov 2021
    Chicagoland
    Engine cover and rear tubs
    Another one of those little STi gotcha moments is that the Intercooler won't fit under the engine cover. I'm still not 100% decided about how to deal with it ( a whole new engine cover design...?), but experimented with a couple of solutions.
    I made some vertical supports for engine cover to rest on and give about 3/4" clearance.
    The normal cover pin locations pull down okay, though with added cover to side gap.
    In the front I lowered the aluminum block plate in the front of the engine cover and added some slide in catch features. This will allow fairly easy one person handling and raises the front of the engine cover about 1-3/4".
    All this raising caused the vestigal "wings" to be elevated. I didn't want screws or anything that would require a tool and inhibit quick cover removal. I ended up with old school Dzus fasteners (I won't tell which service I stole them from many years ago if you don't). These will be down in a couple of yet to be developed scoops in this area to grab air for the IC.
    Finally I installed the rear wheel tubs. This was by far the most difficult part of assembling this car. Nothing fit as expected, when I finally got one in position with all the hands and clamps I have, drilled a hole and it would move out of position. Finally completed with suitable amount of sweat and profanity .
    Sunday is the first outing beyond up and down the block. Going to a small club auto cross as a first shake down.
